Jammed collet - Router Forums
 3Likes
  • 1 Post By Cherryville Chuck
  • 1 Post By Stick486
  • 1 Post By Herb Stoops
post #1 of 7 (permalink) Old 09-07-2018, 10:09 AM Thread Starter
Default Jammed collet
I have a Erbauer 2100w router. Since buying it I have only used 1/4 inch bits. Now I can't get the 1/4 inch collet out. Oh yeah and the manual the collet nut is loose but it will not come off. HELP! I need advice
AndyH44 is offline
post #2 of 7 (permalink) Old 09-07-2018, 10:23 AM
Hi Andy and welcome. You've completely unthreaded the nut and it still won't come off?
Herb Stoops likes this.
post #3 of 7 (permalink) Old 09-08-2018, 12:03 AM
old55's Avatar
First Name: Ross
Welcome to the forum Andy.
Ross,
old55 is online now
post #4 of 7 (permalink) Old 09-08-2018, 12:10 AM
see if there's something in these that'll help...
Rogerdodge likes this.
post #5 of 7 (permalink) Old 09-08-2018, 10:16 AM
Garyk's Avatar
First Name: Gary
Try some Liquid Wrench.
Garyk is offline
post #6 of 7 (permalink) Old 09-09-2018, 04:02 PM
Some routers have collet nuts that have a stop. When you reach the stop the nut seems to stall,if you go further it pops the collet free from the shaft and then releases the bit to freely be removed. If the nut is removed the collet is removed too inside the nut.
Cherryville Chuck likes this.
Herb Stoops is online now
post #7 of 7 (permalink) Old 09-13-2018, 02:41 PM
rwhpi1's Avatar
First Name: Robert
Andy,
Hopefully, you've already solved your stuck collet problem. If not, this method has always worked for me. Tightly wrap the bit top with a shop rag to protect the cutters - about 5 turns. Place the collet wrench on the nut and use a small "pipe wrench", placed around the wrapping. Wrench handle should be on your right. Use the tightened wrench to turn the bit, clockwise. When the bit moves, reverse the wrench (handle on your left) and turn it counterclockwise. Also, apply a slight pulling pressure with each movement to remove the bit. Repeat process, until bit is out of the collet. A small pipe wrench gives a firmer grip than a crescent and is less apt to tear through the rag, causing cutter damage. It's also a good idea to have a helper hold the router while you perform the task.
-Bob
rwhpi1 is offline
bits and collet issues captflx Router Bits - Types and Usage 11 04-28-2017 08:21 PM
Craftsman 1/2" collet jimmiler General Routing 3 01-06-2017 10:21 PM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router Collet jammed rmq11 General Routing 3 07-05-2005 09:23 AM
