Anyone use steel cutting router bits? - Router Forums
 9Likes
post #1 of 22 (permalink) Old 10-07-2018, 06:40 PM Thread Starter
aluminumwelder's Avatar
First Name: elliott
Default Anyone use steel cutting router bits?
Yes I know, no one routers steel.
I would of said the same thing about cutting steel with a circular saw blade years ago, but steel cutting blades have transformed the small metal shop and they actually work good, technology to the rescue.
SO I noticed metal cutting router bits on McMaster, ,just search for Router Bits for Steel and Stainless Steel
I'd post the link, but since I am new can't.
anyone try them? I need to make a 1/32 to 1/16 inch deep grove on a 12" diameter 1018 steel circle (basically a 11.5" diameter groove along the inside) and this might be just want I need.
If that does not work I will probably use a diamond blade on a grinder. it will look ratty, but functional. Need to do 100 circles like this so was going to use a simple circle jig.
I know I should buy a metal lathe, not in the budget, although I might break enough bits to make me regret that decision. lol.
if you are curious this is to attach UHWM trim and make a very low friction circle for a cnc machine.
aluminumwelder is offline
post #2 of 22 (permalink) Old 10-07-2018, 07:47 PM
roofner's Avatar
First Name: Gary
I have not but bought a ferrous metal circular saw blade and cut steel roofing with my ez tracksaw. Cut clean and straight as could be. I was very impressed. Blade was from harbor freight. No jagged edges at all just like factory edges .
roofner is offline
post #3 of 22 (permalink) Old 10-07-2018, 10:07 PM
What speed are those McMaster bits meant to turn?
post #4 of 22 (permalink) Old 10-08-2018, 03:11 AM
TWheels's Avatar
The cutting diameters range from 1/8 inch to 3/8 inc to 3/8 inch, with shanks of the same diameter, so the rotational speed i probably in the 20,000 rpm range.
roxanne562001 likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #5 of 22 (permalink) Old 10-08-2018, 07:13 AM
john60's Avatar
There are carbide bits for high speed grinders ( know as burrs in some circles The double cut ones cut faster). These work in routers without issue. Use light passes
john60 is offline
post #6 of 22 (permalink) Old 10-08-2018, 10:03 AM
No issues with metal fragments being tossed at high speed?
post #7 of 22 (permalink) Old 10-08-2018, 10:56 AM
JOAT's Avatar
First Name: Theo
Could wear a jacket, and probably take care of that. What I would like to know, is there any issues with sparks? One of the last things I need to do is burn down my shop.
JOAT is offline
post #8 of 22 (permalink) Old 10-08-2018, 12:28 PM
TenGees's Avatar
First Name: Paul
Here's a guy using a regular carbide router bit on steel. I believe he's running at a much lower speed than on a router though.
Go to 21 minutes in...
harrysin and DaninVan like this.
TenGees is offline
post #9 of 22 (permalink) Old 10-09-2018, 10:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Who would have thought it, certainly not me. Thanks for posting it Paul/
Harry
harrysin is offline
post #10 of 22 (permalink) Old 10-10-2018, 09:15 PM
First Name: martin
https://www.youtube.com/watch?v=NZyyb7aeiY0
definitely a much slower speed, and a lot more torque too, that's a milling machine he's using!. carbide milling bits used on steel have a TiN coating to reduce the wear from the action of the iron on the carbide though..
radios is offline
MCLS Router Bits sreilly Router Bits - Types and Usage 69 09-09-2019 11:33 AM
Hello OBG65 New Member Introductions 20 05-06-2018 10:34 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
