small flush trim bit - Router Forums
 12Likes
post #1 of 24 (permalink) Old 10-15-2018, 11:04 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default small flush trim bit
I'm looking for the smallest pin guided flush trim bit i can find.
I want to use a template to make multiple copies, but i need a very thin flush trim. I cant see a bearing being small enough, anyone?
sunnybob is offline
post #2 of 24 (permalink) Old 10-15-2018, 12:13 PM
Roto Zip bits..
https://www.homedepot.com/b/Rotozip/N-5yc1vZ1ak
Stick486 is offline
post #3 of 24 (permalink) Old 10-15-2018, 02:32 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Nope.
Imagine a bearing guided flush trim bit. Now imagine that bit only 3/16" diameter. I need a guiding surface to follow the template.
I have pin guided round over bits, but I cant find a straight flush trim with a pin guide.
sunnybob is offline
post #4 of 24 (permalink) Old 10-15-2018, 02:41 PM
yup...
Roto Zip bits..
Stick486 is offline
post #5 of 24 (permalink) Old 10-15-2018, 02:49 PM
Semipro's Avatar
First Name: John_*
Default rotozip
Bob
Rotozip straight bits have no cutting edge on the first quarter inch which is used to guide the bit around the outside of say electrical boxes,but think the smallest is 1/8”
Semipro is offline
post #6 of 24 (permalink) Old 10-15-2018, 03:05 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Ahh, thats clearer thanks. The first link just looked like abrasive drill bits to me.
Now I just have to find a supplier a few thousand miles nearer.
sunnybob is offline
post #7 of 24 (permalink) Old 10-15-2018, 03:11 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
looks like these are 1/8" shafts. I want it for my router table. 6 mm is the smallest collet I have.
Still looking.
sunnybob is offline
post #8 of 24 (permalink) Old 10-15-2018, 04:07 PM
CharleyL's Avatar
First Name: Charley
They sell adapters to use Roto Zip bits in 1/4" router collets here, so they may also offer them elsewhere. I use them with the adapter in my smaller routers.
Without a bearing on the tip they require a lubricant or you will burn the edge of your template. This is also helpful if using a router bit with a brass guide tip. I brush a thin layer of Vaseline on the template edge where the guide tip will rub. I also do this when using the solid carbide laminate trimmer bits to trim laminate, basically any bit that has a smooth guide but no bearing, or a bearing that isn't spinning all that free. It can make a mess if you use too much, but it does eliminate the the burning.
Charley
Herb Stoops likes this.
Central North Carolina
CharleyL is offline
post #9 of 24 (permalink) Old 10-15-2018, 04:39 PM
JOAT's Avatar
First Name: Theo
On the few occasions I want to go less than my 1/4" flush trim bit, I use a scroll or sabre saw, works well for me, even if doing multiples. I call templates masters.
JOAT is offline
post #10 of 24 (permalink) Old 10-15-2018, 05:01 PM
1/8'', 5/32'' and 1/4''
Stick486 is offline
Which bits... a deep rabbit hole... AshleyJ Router Bits - Types and Usage 15 03-10-2018 08:36 PM
Long flush trim bit, 1/4 shank, for sink cutout snorton Router Bits - Types and Usage 17 07-08-2017 03:28 AM
flush trim bit carl.p Router Bits - Types and Usage 3 01-13-2014 07:37 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
Flush Trim Bit? cbsjoez1935 Router Bits - Types and Usage 5 07-28-2007 11:35 AM
