Key Hole Hanger - Router Forums
 8Likes
post #1 of 27 (permalink) Old 10-30-2018, 10:58 PM Thread Starter
Default Key Hole Hanger
I have make some simple shelves and want to use a key hole router bit to cut some hanging slots to hang them
I would like to put them vertical on the back ...taller part. I'm not sure what the best way to do this would be.
Or should I put them horizontal on each end ?
Any suggestions for using the key hole router bit to cut hanger on the back of my shelves ?
MBurke is offline
post #2 of 27 (permalink) Old 10-30-2018, 11:06 PM
how wide of a piece do have to cut the keyhole slot in???...
what is the weight of your shelf???... size???...
a single horizontal cut is most forgiving for centering/balancing.leveling...
post #3 of 27 (permalink) Old 10-30-2018, 11:23 PM Thread Starter
Two shelves are 14" wide/long
One is 30" long
All three are 6" deep.
They don't weight much...popular and maple
Going to set picture and small stuff on them
I would like to put a hanger slot on each end.
MBurke is offline
post #4 of 27 (permalink) Old 10-30-2018, 11:31 PM
Remember that the slots have to be in the same orientation to work. You can’t go inward from each end. They’ll need to be deep enough to leave enough shoulder to support the load.
jj777746 likes this.
post #5 of 27 (permalink) Old 10-30-2018, 11:55 PM
JOAT's Avatar
First Name: Theo
If it was me I would go with a French cleat.
DesertRatTom and MYB like this.
JOAT is online now
post #6 of 27 (permalink) Old 10-31-2018, 12:26 AM
One is 30" long
how thick??? what material are the shelves???
you trying to hang these shelves straight (blind/floating) to the wall like so...
if you are, a keyhole slot won't work for very long...
there is hardware just for the task at hand...
post #7 of 27 (permalink) Old 10-31-2018, 06:12 AM Thread Starter
The backs are 3/4 x 2 x length
Popular
I want them floating but there not going to hole that much weight
I know they cant come in from both ends
Maybe I should look at some of these
https://www.rockler.com/keyhole-fitt...RoCThkQAvD_BwE
MBurke is offline
post #8 of 27 (permalink) Old 10-31-2018, 06:45 AM
that's a better move...
post #9 of 27 (permalink) Old 10-31-2018, 07:28 AM Thread Starter
OK
I could just screw them to the wall . No one will see the screws anyway.
Thanks for the help
MBurke is offline
post #10 of 27 (permalink) Old 10-31-2018, 08:04 AM
those brackets go on shelf...
screw goes in the wall..
Danman1957 and TenGees like this.
Key Hole Bit rnubee CNC Routing 12 02-22-2018 04:13 PM
key hole slot cutter? ben67 Jigs and Fixtures 4 02-17-2009 08:17 AM
Key Hole Jig dan morrissette Jigs and Fixtures 8 01-17-2008 02:27 PM
Key hole jig jgusher New Member Introductions 2 10-21-2006 10:55 AM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 05:29 PM
