Router Bit For Aluminum - Router Forums
 31Likes
post #1 of 27 (permalink) Old 11-08-2018, 11:09 PM Thread Starter
First Name: Doug
Default Router Bit For Aluminum
I haven't tried routing aluminum, But I've heard of people doing it!
I'm looking for any tips & bit recommendations for routing some 1/8" thick aluminum.
What I'm looking to do is epoxy a 1/8" thick aluminum cover onto a drill press table & then route out the slots for the tables T-Slots.
Here's a few before & after pictures of the drill press table I'm planning to add the aluminum top/cover to.
TenGees likes this.
dwall174 is offline
post #2 of 27 (permalink) Old 11-09-2018, 12:20 AM
All aluminum is not equal. Stay away from SO grade it is soft and will gum up your bit. The harder the aluminum you can get the better. Also use a coolant on it when you rout it, it will be messy you will have coolant and chips all over and running onto the floor. The coolant is water and oil emulsion. Are you cutting it outside or on your router table ?
You might consider cutting the plate into strips on the table saw and spacing them out the width you want, that is only 2 cuts. I have dry cut aluminum on the TS before, be careful feed it slow.
mjadams61 likes this.
Herb Stoops is online now
post #3 of 27 (permalink) Old 11-09-2018, 12:30 AM
Semipro's Avatar
First Name: John_*
nice job on the restorations of the table
Yes you can router Aluminum here a video showing it being done
Semipro is offline
post #4 of 27 (permalink) Old 11-09-2018, 11:45 AM
MEBCWD's Avatar
I worked in the aerospace industry for many years making custom cabinetry for planes, everything from Gulfstreams to Boing 777's. We custom made a lot of the hardware and used 2024-T3 clad aluminum. It cuts well on a tablesaw using a carbide metal cutting blades but can be cut with carbide wood blades, the cut is not as good with the wood blade. We used standard carbide router bits, usually, Amana or Whiteside but other good quality bits will work fine.
The 2024-T3 clad aluminum is great for template routing. You can make your templates just like you would for wood items. Good sharp carbide bits leave a good edge, don't use a dull bit thinking you don't want to ruin a good bit. A dull bit will not give you a good cut and will also generate more heat and cause more problems. Use a steady feed, not too slow or you might heat up the aluminum and cause welding, same as you would use when routing wood.
TWheels and mjadams61 like this.
MEBCWD is online now
post #5 of 27 (permalink) Old 11-09-2018, 12:29 PM Thread Starter
First Name: Doug
Originally Posted by Semipro View Post
nice job on the restorations the table
Thanks for the complement!
Most of the repairs were done with nickel welding rod, A final coat of JB-Weld was used to fill in any gaps caused from the welding.
That helps out quite a bit, Thanks!
I was thinking of something similar to what was shown in the video.
My idea is to make a plywood template (larger than the top) that locates the slots & also provides extra support for the router while near the out-side edges.
dwall174 is offline
post #6 of 27 (permalink) Old 11-09-2018, 01:33 PM Thread Starter
First Name: Doug
I already ordered a 1/8" thick, 18" X 18" piece of aluminum from Amazon the other day.
It's 5052 aluminum! Not sure if it's soft or not, But that's what I'll be working with when it gets here.
You might consider cutting the plate into strips on the table saw.
Saw cutting may be a possible option, But in my case I would probably use my customized RAS.
I have a RAS that I added T-tracks to, It makes a big difference being able to clamp the piece being cut to the table.
Here's a pic. of my RAS top!
Last two pics. are of a set-up I used to re-cut a lift gear for the drill press I'm working on.
The cast-iron gear had several damaged teeth that I welded with nickle rod & re-cut the teeth with a 10" abrasive wheel.
CharleyL, DaninVan, Biagio and 2 others like this.
dwall174 is offline
post #7 of 27 (permalink) Old 11-09-2018, 02:20 PM
TWheels's Avatar
5052 aluminum is 2.5%(weight) Magnesium, 0.25% Chromium. It is described as suitable for universal, aerospace, marine use. Seems like a good choice for the purpose.
Herb Stoops likes this.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #8 of 27 (permalink) Old 11-09-2018, 04:53 PM
@dwall174
Great setup on the RAS. The 5052 is a good choice. The Glaziers use the Johnson stick wax on their chop saws for cutting Aluminum. But I think that it is a thing of the past,
here are the latest:
[url]https://www.amazon.com/cutting-wax-stick/s?page=1&rh=i%3Aaps%2Ck%3Acutting%20wax%20stick[/url
From the looks of your setups ,you are competent in metal working.
post #9 of 27 (permalink) Old 11-09-2018, 11:36 PM Thread Starter
First Name: Doug
Thanks!
Yeah 8 years working in a machine shop will do that!
I mainly ran a Bridgeport, But I would also run a lathe & surface grinder at times.
dwall174 is offline
post #10 of 27 (permalink) Old 11-09-2018, 11:48 PM
Country: South Africa
First Name: Biagio
Great idea for the RAS table, hope you won't mind if I steal it. Can't believe that nothing like that had occurred to me in 40 years of owning one, and cursing with holding down thin pieces.
Might I ask what the array of holes on the fence are for?
Biagio is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 05:18 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
