Amazon router bits - Router Forums
 29Likes
post #1 of 29 (permalink) Old 11-23-2018, 04:46 AM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Default Amazon router bits
My parents are looking for Christmas ideas for me and I literally don’t know what to suggest because I never want to have them buy expensive things for me, so, I’m trying to come up with low cost things that won’t be a total waste of money. I’m also realistic in what I expect quality wise with anything low cost, but I still want to ask this.
On amazon they have Yonico router bits in lots of different profiles. I’m thinking I can use some replacements for my straight bits as well as maybe pick up an edge profile or two that I don’t have now. Also, keep in mind that 90% of my work is on soft white pine 2x lumber from Lowe’s so I don’t necessarily need high quality bits that will handle hard woods, but I don’t want just pure junk either. When I began woodworking I bought a set of Skil branded bits from Lowe’s and they have satisfied me quality wise. I’m wondering if these Yonico bits would at least be equal to those? If so then I think a $25 set of straight bits would be ok and keep their cost down on buying stuff for me.
Also I see lots of other yellow bits being sold that have the identical same photos, but not the same name. Makes me wonder if it’s possible to save even a few more dollars at times on those, or if I’m seeing knock offs with pirated photos for the sake of the listing.
Duane Bledsoe is offline
post #2 of 29 (permalink) Old 11-23-2018, 04:48 AM
gift certificate..
MEBCWD, jj777746 and honesttjohn like this.
post #3 of 29 (permalink) Old 11-23-2018, 06:56 AM Thread Starter
First Name: Duane
I’ve thought about that but you’d have to know mom. She thinks gift certificates are not very “gifty”. Never has gotten on board with that. We had to explain that iTunes cards are not gift cards, it’s the only way to buy iTunes music. Seemed the same to her.
MEBCWD likes this.
post #4 of 29 (permalink) Old 11-23-2018, 06:59 AM
First Name: Steve
I have bought a few Yonico bits and they are not that bad. I have not used them for large high production work, but for a hobbyist they have suited me well. Others may disagree, but for the money I believe they are a good value.
Herb Stoops and mjadams61 like this.
Knot2square is offline
post #5 of 29 (permalink) Old 11-23-2018, 07:36 AM
TenGees's Avatar
First Name: Paul
Duane, I bought a set of 'yellow' bits that came in a wood box. They are no comparison to good bits but I've used them quite a bit. The carbide is a lower grade and it's much thinner. The welds are suspect but they've never let any shrapnel fly. I haven't measured them but 'by eye' I think the 1/4 inch straight bit is what I call a 'metric quarter'. Up here in Canada I occasionally buy Busy Bee's house brand Blue Tornado bits. They are noticeably better than the "yellows". Busy Bee is much like Harbor Freight but they don't sell no-name electric hand tools, so I'm not sure who sells similar line of bits in the USA or online. They must be out there because these are just 'branded' off-shore bits.
If you want to replace bits that you use very often, it would probably be worth buying higher quality bits though.
DaninVan and Danman1957 like this.
TenGees is offline
post #6 of 29 (permalink) Old 11-23-2018, 08:31 AM
First Name: Art
If you plan on not doing production work then defiantly get them. The average user will get a lifetime of work out of a cheap set of bits. There are those that will argue that cheap bits aren't worth the price but I have never found that to be true. Years and years ago I bought a cheap set off of ebay and still use them. I have a number of expensive bits but they are specialty ones and didn't come with the set. For the run of the mill cove, rounding, ogee etc the cheap ones work fine.
Herb Stoops likes this.
mgmine is offline
post #7 of 29 (permalink) Old 11-23-2018, 08:43 AM
chuckgray's Avatar
First Name: Chuck
I have many of the Yonico bits and they have worked very well for me and I work mainly with hardwood. I have been using them for several years as a hobbyist. For softwood, they will work very well for you.
chuckgray is offline
post #8 of 29 (permalink) Old 11-23-2018, 09:15 AM
Semipro's Avatar
First Name: John_*
Amazon sells lot of woodworkering equipment including brand name router bits
Do you have micro-gripper push pads Amazon 50.00,white side router bits and the list goes on
Semipro is online now
post #9 of 29 (permalink) Old 11-23-2018, 10:23 AM
Bob Jurgens (Bj3) used them and he said they were great for the price. I bought several in architectural profiles like a table edge for example. I still haven't used them but they were about $25 compared to $100-125 for something similar from Freud or Amana. I won't use them enough to justify buying the good ones.
The quality appears to be excellent just by looking at them. They are sharp and were sharpened to 600 grit it appears because they are as smooth as the good ones and the carbide is as thick as anyone else's. The paint job is well done too. Visually they appear as good as all the top brands. They are also pretty good to deal with. Shipping was pretty reasonable even to up here. You don't need to go on Amazon or ebay to buy them. They sell under the name Precision bits. Router Bits - Precisionbits.com They also gave me a $5 certificate for my next purchase when I bought.
post #10 of 29 (permalink) Old 11-23-2018, 10:54 AM Thread Starter
First Name: Duane
Thank you for the link, I saved it and looked around the site. Yeah I don’t use my stuff much at all, honestly, so these bits should do me fine.
I remember Bob. Great guy to talk to and he really knew his stuff. Occasionally I still run across one of his old posts when doing online searches for certain things.
MCLS Router Bits sreilly Router Bits - Types and Usage 69 09-09-2019 11:33 AM
Router speeds for different bits and types of wood judasentinel General Routing 15 05-21-2018 12:43 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
