One end not routing even! - Router Forums
 12Likes
post #1 of 15 (permalink) Old 11-23-2018, 06:04 PM Thread Starter
Knothead47's Avatar
Unhappy One end not routing even!
I have a Kreg bench-top router table. I'm making a little surprise for you-know-who. My wood is a plain piece of 1X4 pine. The piece is about 28 inches long which routed OK with a 1/4" roundover bit with bearing. The long sides routed perfectly. One end routed perfectly, too. Here's the problem. The other end started OK but the cut seemed to indicate that it pulled away from the fence, making a shallow to "no" cut. I have a miter that I made and just checked it for square- perfect. The only thing I can figure is that the end might not be square and moving the wood away from the bit. I might put it on a sanding disk and run it through again. Your experience and advice are appreciated.
The miter is built on a "runner" and is made of wood. I left the back hole a bit oversize to allow for a "fudge" factor. Again, it shows square to the fence.
I can't understand it- I stayed at a Holiday Inn Express! For a week!
That should read "end."
John T.
Knothead47 is offline
post #2 of 15 (permalink) Old 11-23-2018, 06:55 PM
the board is being rotated as you feed it which is easy to do considering the length...
"SNORK Mountain Congressional Library and Taxidermy
post #3 of 15 (permalink) Old 11-23-2018, 07:09 PM
CharleyL's Avatar
First Name: Charley
It sounds to me like you are running your piece between the fence and the bit. This should never be done. The bit should be in a space in the fence and only the needed portion of the bit sticking through the fence.
End routing is a bit tricky, since end grain likes to grab the bit, and the bit will move the piece of wood out of square when it does this. If using a miter gauge during the end cuts you need to clamp your piece to the miter gauge, so the bit can't pull it out of position. A second piece of wood behind the piece that you are cutting, positioned so that the bit cuts into this second piece as it leaves the first piece, will prevent the end of the cut on your good piece from splintering as this second piece will hold the trailing edge of your good piece as the bit cuts it, and the splintering will occur in the second or scrap piece as the bit exits from that one. Better than a miter gauge, is a coping sled. It has clamps for both the good piece and the scrap piece, and handles positioned safely away from where the cutting takes place. There seems to always be something else expensive to buy when woodworking, doesn't there, but then when you don't have the money to buy the fancy one, you can study it, and then make your own out of wood scraps. My first coping sled was shop made, and it lasted for years.
Charley
Central North Carolina
CharleyL is offline
post #4 of 15 (permalink) Old 11-24-2018, 01:33 AM
I'm not sure I'm clear on what you did John but anytime I push an end across a router bit I use a squared push block against the fence and hold the workpiece tightly against it. If that's not clear the watch Marc Sommerfeld do it on youtube, I think when he he was doing rail and styles but there might be other vids of it too.
harrysin, JFPNCM and Danman1957 like this.
post #5 of 15 (permalink) Old 11-24-2018, 06:31 AM Thread Starter
Knothead47's Avatar
Charley, doing all those things but the miter is a simple one and has no clamps. A sled with clamps sounds like a good project for the "To Do" list. What I can't understand is the one end routed perfectly. The the other end is the problem. I thought of moving the fence and using the miter without it with just the miter. Will experiment and see what happens. Thanks.
CC, will look at the recommended videos. Thanks.
John T.
post #6 of 15 (permalink) Old 11-24-2018, 08:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
End grain is routed first then any breakout is cleaned up going along the grain. As has been mentioned, a sacrificial push block is essential going across the grain.
Danman1957 likes this.
Harry
harrysin is offline
post #7 of 15 (permalink) Old 11-24-2018, 08:45 AM
CharleyL's Avatar
First Name: Charley
If you look closely at the grain direction near the end of your work piece, the end that routed OK likely has it's end grain tilted away from your direction of feed, and it's pointing slightly toward the direction of feed on the end that is giving you trouble. The bit is catching on the ends of the grain and ripping it out.
Charley
CharleyL is offline
post #8 of 15 (permalink) Old 11-24-2018, 12:08 PM Thread Starter
Knothead47's Avatar
Charley, will look at the end.
BTW, use to live in central NC. Miss the fresh seafood.
Edit- Just looked at the bad end. It looks rippled as opposed to the smooth cut on the other end. It seems the bit is going against the grain. Now what do I do?
John T.
post #9 of 15 (permalink) Old 11-24-2018, 01:59 PM
TenGees's Avatar
First Name: Paul
John, I think that many people wouldn't use a miter gauge and a fence at the same time. As Charles and Harry said, I would use a square block against the fence, behind your work, as a pusher and try to shave a hair off at a time. I don't know your skill level, so I hope I'm not insulting you.
TenGees is offline
post #10 of 15 (permalink) Old 11-24-2018, 02:21 PM Thread Starter
Knothead47's Avatar
TenGees, no insult taken. I just recently learned to walk upright. Thanks for the sketch. I'm going to play around with the project as I have plenty of wood to work with and can make another if needed. I did the length as I thought it would be the easiest. I am new to routing as I have had this setup for a while but decided to learn how to use it. To all, many thanks for your suggestions!
John T.
Routing tear out guile1 Table-mounted Routing 12 07-19-2014 09:15 PM
Feed Ddirection/Safe handling when template routing on the table? fleetinglyshort Table-mounted Routing 5 03-13-2014 11:20 AM
Help routing end grain w/o tear-out in circular shape cjtboy General Routing 14 01-15-2014 02:44 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
