Safety question - Router Forums
 3Likes
  • 2 Post By DesertRatTom
  • 1 Post By Cherryville Chuck
post #1 of 3 (permalink) Old 11-26-2018, 12:11 PM Thread Starter
Default Safety question
I have a Craftsman Router table. The router base that came with it reads, Model C911 Router Base, Type 2. I have a Porter Cable Router that twist mounts in it to allow the blades to sit above the table surface. Typical. There is a twist lock to fix the router position depthwise. A small piece of the cylindrical router base has snapped off. The router itself appears to be well seated in the base and locks solidly. Is it ok to still use? I cannot find a replacement as Craftsman no longer appears to make it as a separate part.
John R. Fought is offline
post #2 of 3 (permalink) Old 11-26-2018, 12:54 PM
Needs a picture of the broken area. If something like that happened, I would be reluctant to trust it. Time to consider retiring the router?
TenGees and Herb Stoops like this.
DesertRatTom is online now
post #3 of 3 (permalink) Old 11-26-2018, 12:56 PM
Welcome John. It shouldn't be a problem if the router still locks firmly in the cylinder. Be aware that some of those routers with an adjustment ring really weren't designed to used upside down as the adjust ring held the router up at the desired position and the ring didn't necessarily lock to the router base so that if you turned it upside down it would fall out when unlocked. I found out that rack and pinion style adjusters will do the same thing. Luckily nothing broke when I learned that lesson.
Which router model is it? Someone here might have a dead one that is still in good shape.
Herb Stoops likes this.
Hello with a router fence question nevertoosafe New Member Introductions 9 11-02-2014 03:22 PM
Another Question From Jerry Jerry Bowen Tools and Woodworking 19 02-18-2014 12:36 PM
Question About MJ Splitter Jerry Bowen Tools and Woodworking 8 10-03-2013 10:05 PM
Rookie here, got a question wyatt earp New Member Introductions 6 07-18-2008 09:33 AM
DC Question angus Lobby 3 03-31-2008 08:29 PM
