Largest router bit I can use WELL - Router Forums
 5Likes
post #1 of 14 (permalink) Old 11-28-2018, 05:53 PM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Default Largest router bit I can use WELL
I’ve read that my DW618 router will spin a 2-1/2” raised panel bit if taken slowly and the wood not pushed fast through the cut. What’s the largest bit I could use and not have to consider it a compromise? I’ve been looking at some 1-1/2” bottom cleaning and bowl bits for freehand use and with potential built jigs.
Duane Bledsoe is offline
post #2 of 14 (permalink) Old 11-28-2018, 06:14 PM
I wouldn't consider using a 2.5 inch bit freehand, far too much danger of it flying loose and heading at high speed to a major artery. Big bits are for table use.
The power of the router makes some difference, of course, but it helps to cut several times, taking off a little more each pass. I limit myself to about 1/8th per pass by leaving the height pre set, and moving the fence back a little after each pass.
post #3 of 14 (permalink) Old 11-28-2018, 08:07 PM Thread Starter
First Name: Duane
Sorry, I wasn’t very clear on what I meant. That’s what I get for rushing my post while trying to leave the house. What I meant was I know the 2-1/2” bit can be used in my router and in a table, but it seems like a compromise because I can’t just put it in and use it without giving it another thought like I can a 1/2” roundover. That got me to wondering what’s the largest bit I could use and not really have to worry that the router isn’t strong enough to spin it well? I’m wanting to pick up a bit that I can use for a planing jig. I want to make a jig that allows me to pass a board through and run my router over it to thin it down. I was looking at a bowl carving bit or a bottom cleaning bit and I found them in various sizes in 1/4” increments. I figured 1-1/2” would be large enough to be servicable while not being too stressful on the router.
Also the bowl carving bit seems less likely to leave lines than the bottom cleaning bit would. Any thoughts on this?
post #4 of 14 (permalink) Old 11-28-2018, 08:16 PM Thread Starter
First Name: Duane
Was just recalling, I have a rabetting bit that would be along the lines of this in terms of size and weight. If it works then a bowl carving bit would also work. So I guess I just need to get one and start building a jig.
post #5 of 14 (permalink) Old 11-29-2018, 01:37 AM
It's not necessarily how big a bit as much as it is how deep a cut and how fast a feed speed Duane. You can compensate for the lower horsepower. I've run 1.5" bits in a 3+ hp router for leveling and I don't recall even having to go that slow but I was probably only taking off a 1/16th.
post #6 of 14 (permalink) Old 11-29-2018, 05:44 AM Thread Starter
First Name: Duane
That’s what I want to do, but I only have a 2-1/4 HP router. It would be really great if I could run up to 2” bits. Do you think a DeWalt DW618 would handle a bit that large while shaving off a 1/16” of wood, ran on the slowest speed setting the router has?
post #7 of 14 (permalink) Old 11-29-2018, 06:22 AM
in all of this is the information for you to make up your own mind...
post #8 of 14 (permalink) Old 11-29-2018, 08:13 AM
sreilly's Avatar
First Name: Steve
Duane it's best to go over the information Stick is referring to and understand it before attempting anything like this. I have a 2-1/4HP Bosch and it can do raised panel cuts just fine but the speed needs to be adjusted for the bit size and the face amount/depth needs to be appropriate for the router by making repeated cuts. Look for a speed chart for your router that explains the speeds vs bit diameter. But certainly look at the above info Stick refers to. It would be a mistake not to.
sreilly is offline
post #9 of 14 (permalink) Old 11-29-2018, 08:43 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This 1 1/4" dish cutter, second shot, has had regular use in hand-held router and as has been said, there is little chance of lines between cuts compared to a bottom cleaning bit which must be set absolutely square to the work-piece.
Name:	planing test3.jpg
Harry
harrysin is offline
post #10 of 14 (permalink) Old 11-29-2018, 11:20 AM
If the material isn't flat, bowedor twisted, you'll need to prop it up in order to flatten it uniformly across the full width. You will also want to have a jig to guide the 618 router as it flattens the top. If you have a good #4 or #5 hand plane, you could shave down the high spots on the inside of any bowing to help level it so it is stable on the work surface. Stick's pictures show the router running on a pair of bars.
The two pictures show variations on simple router sleds. Note that the outside long edges have an added piece on each side to restrain and guide the router as you move it across. Once the workpiece is planed or propped up, you adjust the depth of cut by raising or lowering the bit. Go lightly in small steps until a straight edge show's it is flat on one side. If you have a planer, you can level the other side, or flip it over and use the router to cut the otherside til it's flat. You will still need to do a little sanding and scraping to have a finished surface. You'll need to buy stock somewhat thicker that your desired finished thickness.
Harry's Router Sled jig uses metal bars to keep the bit cutting level all the way across, the pictured designs use some very flat Baltic Birch ply for the guide's runners. The smaller edge guides reinforce the jig and keep it flat. The opening needs to be a little wider than the biggest bit you plan to use. The opening doesn't need to be adjustable since the outside guides need to be a close fit to the router base.
Notice that the picture with the slab shows use of wedges to level off and keep the slab from rocking.
It is flattening the second side that renders the piece parallel and usable. Note that in the second picture, the maker used aluminum "L" bars.
Name:	Router sled 2.jpg
Name:	Router sled 1-.jpg
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
