DeWalt plunge router. Model DW621 - Router Forums
 2Likes
post #1 of 11 (permalink) Old 12-27-2018, 09:44 AM Thread Starter
First Name: Joe
Default DeWalt plunge router. Model DW621
I'm kind of in the market for a new/used good router for a reasonable price.
Found this one offered: DeWalt plunge router. Model DW621. with bushing kit.
Questions. Is it:
Reliable, especially speed control?
Removable from the base and table mountable?
What is a reasonable price?
joea is offline
post #2 of 11 (permalink) Old 12-27-2018, 10:22 AM
The only plunge routers detachable from the base are the kit ones. The rest are one unit. Most plunge routers don't need to be in a lift. A lot are above table adjustable and the rest can be adapted, such as with a RouterRaizer.
post #3 of 11 (permalink) Old 12-27-2018, 10:54 AM Thread Starter
First Name: Joe
Thanks. After I looked at the pictures of the various units it became obvious from the looks of the case.
The search is now on the back burner for a few weeks for unrelated reasons.
joea is offline
post #4 of 11 (permalink) Old 12-28-2018, 12:54 AM
JFPNCM's Avatar
First Name: Jon
I have a 621 with the plunge kit and find it very reliable and useful as a general router. As Chuck pointed out it is not one to use in a lift. I would check out stand alone motor systems if you want to keep it in a lift on a table.
Jon
JFPNCM is offline
post #5 of 11 (permalink) Old 12-28-2018, 07:34 AM Thread Starter
First Name: Joe
Any suggestions to look at for a stand alone?
JFPNCM likes this.
joea is offline
post #6 of 11 (permalink) Old 12-28-2018, 08:16 AM
you can't go wrong..
https://www.cpooutlets.com/factory-r...efault,pd.html
JFPNCM likes this.
post #7 of 11 (permalink) Old 12-28-2018, 10:44 AM
JFPNCM's Avatar
First Name: Jon
@joea
I have a PC 7518 in my Rockler lift and have no problems with its performance but if I were starting over I would follow Stick’s suggestion.
Jon
JFPNCM is offline
post #8 of 11 (permalink) Old 12-28-2018, 11:22 AM Thread Starter
First Name: Joe
Heh. Being familiar with CPO outlets, I went looking for "motor only" units and came up empty. Then I followed the link.
joea is offline
post #9 of 11 (permalink) Old 12-28-2018, 11:48 AM
@joea
I have a PC 7518 in my Rockler lift and have no problems with its performance but if I were starting over I would follow Stickís suggestion.
must be an older 7518...
post #10 of 11 (permalink) Old 12-28-2018, 12:03 PM
JFPNCM's Avatar
First Name: Jon
It is Stick. Donít recall when I bought it. It was recommended by Rockler at the time as it fit their lift very well and was available as the motor only. I donít use it regularly but when I do it gets worked.
Jon
JFPNCM is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Fixed router with lift or Table ready plunge router with new Plate? JohnnyB60 Table-mounted Routing 9 02-07-2016 10:58 AM
Home built Router Lift for Dewalt DW621 router Tinman Carving Table-mounted Routing 9 10-07-2015 08:15 AM
Mastercraft Plunge Router, model 54-7036-6 Missing User Manual Marty.R.W General Routing 2 07-29-2012 07:07 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
