Newbie question on rounding an edge using a small trim router. - Router Forums
 6Likes
post #1 of 11 (permalink) Old 01-08-2019, 09:05 AM Thread Starter
Default Newbie question on rounding an edge using a small trim router.
I'm new to using routers and I only have a small drillmaster 1/4" trim router. Its too small to fit in my router table. Can I round an edge with it and if so what bit and size do I use ? The board is a desktop and its 5/8" thick. I appreciate any input and suggestions. Thanks
Woodman001 is offline
post #2 of 11 (permalink) Old 01-08-2019, 11:18 AM
Roundover bits are some of the most common bits and are normally what is used for rounding edges as long as you leave a flat in the center of the edge for the bearing to register against. Even when rounding the full edge round I'll still somethimes use a roundover bit instead of a bull nose bit which rounds both edges at the same time. When rounding the full edge over you need to either do it on a table with a fence or clamp a straight edge to the board or use a guide attached to the router. The bit(s) to round a 5/8" thick board are relatively small so you shouldn't have any problem running them but the key is to always listen to the router and if it is running too slow then slow your feed rate down. That's true no matter what size router you are using. Welcome to the forum by the way.
DaninVan, TenGees and Herb Stoops like this.
post #3 of 11 (permalink) Old 01-08-2019, 11:23 AM
Hey, Woodie; welcome!
Absolutely, no problem. I use my old Ryobe (sp?) trim router (very low power) for rounding over all the time. The most important point is to make sure you use really good quality, sharp, round-over bits.
A larger 5/8" or 3/4" might be pushing it a bit but a 1/4" or 3/8" radius should be a piece of cake.
Are you clear on the concept of "climb cutting"? with your workpiece in front of you you need to run the router from left to right; that's the correct direction...you're running so that the bit pulls into the workpiece. Having said that, I like to do a 'climbcut'...right to left...as a final finish pass after all the waste wood has been routed away. There's nothing remaining for the bit to grab, but it does leave a really clean surface.
You're looking foe 1/4" shank bits ...
Corner Round Over Bits - Lee Valley Tools
You might want to check those prices against Freud prices.
*those are in Canadian $$$$ US prices should be quite a bit less(?). Sorry, no pun intended.
DaninVan is online now
post #4 of 11 (permalink) Old 01-08-2019, 11:39 AM
Welcome to the forum. You can get roundover bits almost anywhere, here's a picture of a Freud set with 1/4 inch shanks (shafts). The bearing rides against the edge you're rounding over, so of you have thin stock, you might use double sided (carpet) tape to add a second board under the first, even with the edge you're routing so the bearing has something to ride on.
Second pix is of a router mounted on an edge guide. You can use a small (trim) router for a lot of different cuts, just don't take off very much at one time. The guide would allow you to cut a groove or dado in many small (1/16th or so) passes without wandering off the line. Not sure if your brand router has that accessory available.
As you get more serious about woodworking, consider getting a Bosch 1617 EVSPK, which is a kit with both fixed and plunge base. You can use the fixed base to mount in in a table (safest way to work). The Bosch has an amazing array of accessories including a really top notch edge guide that will also help you cut circles.
Sounds like you might be starting into woodworking, so I've attached a pdf of the 17 or so things that helped me accelerate the learning curve. It may help you avoid some of the costly mistakes I've made. If you aren't wearing a dust mask whenever you work with the router or any other tool, go get at least one of the 3M masks and always wear it. The really fine sawdust, once in your lungs, never comes out. COPD and restricted breathing is no fun.
Ditto to Dan's comments. The height of the bit makes the difference in the appearance of the cut. The drawings with the bits show what it looks like with the bit set pretty high, it leaves a flat above and below the roundover. Lower the bit and the flats go away.
Name:	roundover bit sset.jpg
DaninVan likes this.
post #5 of 11 (permalink) Old 01-08-2019, 06:36 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
post #6 of 11 (permalink) Old 01-09-2019, 10:48 AM
TenGees's Avatar
First Name: Paul
I usually keep a 1/4" round-over bit in my trim router. That's what it gets used for most often.
TenGees is offline
post #7 of 11 (permalink) Old 02-07-2019, 01:46 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi Tom.
Looks like the item 17 at the attached pdf, very interesting BTW is aimed to a particular forum member. Just kidding, Rick.
We, woodworkers are everywhere!!!
papasombre is offline
post #8 of 11 (permalink) Old 02-12-2019, 10:39 PM
You can simply Go to a team because they have an expert team to solve your quarry.
joeroot is offline
post #9 of 11 (permalink) Old 02-12-2019, 10:41 PM
joeroot is offline
post #10 of 11 (permalink) Old 02-12-2019, 10:46 PM
joeroot is offline
Router Newbie Metalsuitman General Routing 10 01-03-2012 08:09 AM
1"x2" pine, what rounding edge router bit do I need for a flush edge? annmariehawkins Router Bits - Types and Usage 5 12-04-2010 12:00 PM
