Triton trb001 brushes seized - Router Forums
 3Likes
post #1 of 13 (permalink) Old 01-20-2019, 08:03 AM Thread Starter
First Name: Dave
Default Triton trb001 brushes seized
Good afternoon, UK time.
I have just joined your forum in the hope of some advise. I have emailed Triton but no response. I have a TRB001 router which stopped working during door making. Up until now most of my router work has been 'freehand' so to speak but progressed recently to my Triton workcentre. Testing depth of cut for cutters I went to start machine after adjustment and refused to work. I have read posts about it could be the switch, speed controller or brushes. I purchased a new TRA001 but would like to get this TRB001 working as it, as far as I know as I was given it, does not have excessive hours on it. I have looked at the brushes and one of them appears to be frayed on the wiring and both are stuck in place. Enough 'waffle'!
My question is:- How can I remove these brushes for replacement without pulling on them with the risk of making matters worse?
I await any suggestion.
Many thanks in advance.
sebmoc is offline
post #2 of 13 (permalink) Old 01-20-2019, 09:09 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
brushes are held in place by spring clips, or sometimes folded over tabs.. Just look closely at what is holding the brush spring in place and find a way to remove it.
sunnybob is offline
post #3 of 13 (permalink) Old 01-20-2019, 10:43 AM Thread Starter
First Name: Dave
Hello Sunnybob. Thanks for your reply but on the Triton TRA/B001 it is held in place by the brush holder with a cap screw. The brushes should just slip / pull out but even with quite a bit of force they will not budge. They do not seem to be twisted but are stuck solid.
My thoughts are maybe they have expanded. Do brushes expand?
I have placed router, with top cover off, upside down, on top of the radiator with the hope that heat will shrink the brushes if my assumption is correct.
To remove the brush holders I need to have the brushes out as I thought maybe replace brushes and holders in case it is both giving trouble.
Maybe someone here has some thoughts or suggestions on this.
sebmoc is offline
post #4 of 13 (permalink) Old 01-20-2019, 10:53 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Ok, you have option three (lol)
The brushes are solid carbon. They dont expand. It sounds like they have worn so much that there are broken bits jamming them down. Its extremely unlikely you will be able to save those brushes, so you could just break them out with a fine bladed screwdriver, to see in the commutator ring is ok.
sunnybob is offline
post #5 of 13 (permalink) Old 01-20-2019, 11:04 AM Thread Starter
First Name: Dave
Thanks again.
They do not seem that worn but your suggestion to break them out is my thoughts exactly but I did not know whether it maybe an option. Being that you have suggested the same option then I think that will be the way to go.
Many thanks for your time. I shall post results in case it may help someone else.
sebmoc is offline
post #6 of 13 (permalink) Old 01-20-2019, 12:36 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Lets back up a bit before you start destroying stuff.
Does the spindle turn?
if so, does it turn freely?
If so, have you checked the fuse in the plug? It should be a 13 amp fuse. If you have no way of testing, swap it into another appliance that does work.
Do you have any circuit tester (preferably a multitester that measures AC voltage?)
Lets eliminate the simple things first.
sunnybob is offline
post #7 of 13 (permalink) Old 01-20-2019, 12:42 PM
It doesn't look like anything should be holding them (parts 26, 27, 28, and 29 the caps): https://www.tritontools.uk.com/TRB001spares.html
Maybe a pair of needle nose pliers and wiggling them back and forth would loosen them.
post #8 of 13 (permalink) Old 01-20-2019, 12:58 PM Thread Starter
First Name: Dave
All was covered before even posting on here.
Everything worked as it should movement wise.
Power light on switch.
No movement on brushes with whichever implement I tried to move them with.
Finally, toooo late because I have 'smashed' them out.
Just so as not to horrify you. I am a retired tradesman of many years and used to repairing my own tools. Generators, of which I have 3, dewalt chop and bench saws along with numerous drills of many types. Dewalt routers of which are 20+ years old and maintained by self along with numerous other tools including these two triton routers of which one is not even a week old yet bought as replacement for this TRB001.
As stated, the brushes have been broken out and all looks alright. The cause seems to me to be the fact that the brushes corroded to the brush holder. Now the brushes are out there is green corrosion stain on the sides of the brush holders. Nothing that cannot be cleaned.
Thank you again for your replies and time on this issue.
DesertRatTom and TenGees like this.
sebmoc is offline
post #9 of 13 (permalink) Old 01-20-2019, 02:07 PM
Glad you resolved the problem. I have and really like the TRA001, but only use it in the table. The switch interlock on the TRA is a love it or hate it thing. Also with the router raised to it's full height for a bit change, it won't run--safety feature.
post #10 of 13 (permalink) Old 01-20-2019, 02:24 PM
The corrosion probably increased the diameter a bit as well as welding the pieces together. Are there wires going to the brushes or do the brush holding cups transmit the current to the brushes?
Triton TRB001......review. jw2170 General Routing 20 06-02-2014 10:29 PM
Triton TRB001 theRushen Table-mounted Routing 13 09-16-2013 11:34 AM
New Triton TRB001 jw2170 General Routing 28 12-31-2012 04:45 AM
Triton TRA001 or TRB001 WHICH ONE NEWEST Jaccok General Routing 2 11-21-2011 08:46 AM
Triton TrB001 and TRA001 Harmony New Member Introductions 13 09-12-2009 09:31 PM
