Threaded inserts - Router Forums
 18Likes
post #1 of 18 (permalink) Old 01-27-2019, 12:57 PM Thread Starter
Default Threaded inserts
Anyone have a drill size guide for brass threaded inserts?
Sawdust74 is offline
post #2 of 18 (permalink) Old 01-27-2019, 01:13 PM
will this information work???
Arcola60, Danman1957 and sreilly like this.
Stick486 is offline
post #3 of 18 (permalink) Old 01-27-2019, 10:48 PM Thread Starter
Stick, thanks for the info! The Hillman brand is what I used, called them with virtually no help. I used those for my taper jig, making a router table now and will most likely use them again for that.
post #4 of 18 (permalink) Old 01-28-2019, 07:33 AM
sreilly's Avatar
First Name: Steve
Is there any documentation you don't have Stick? That might be a short list from what I've seen in my short time here. You are the man.....
sreilly is online now
post #5 of 18 (permalink) Old 01-28-2019, 08:31 AM
Country: Mexico
First Name: Joseph Anthony
Talking
His real ALIAS is STICKYPEDIA.
TenGees, Stick486, HoweA and 4 others like this.
Cheers.
Joe
RÖENTGEEP is offline
post #6 of 18 (permalink) Old 01-28-2019, 08:34 AM
sreilly's Avatar
First Name: Steve
I knew that was an alias.... Hiding in plain sight he is.
post #7 of 18 (permalink) Old 01-28-2019, 09:28 AM
Gage the bottom end of the insert with a bit gauge. The bottom end is the one that has slots in it like for a straight screwdriver. They are NOT for that purpose! They are actually the cutting edges designed to size the hole to the correct diameter for the threads that follow. Use the bit that matches what the bit gauge says, (or a wee bit slightly smaller but never larger). Most retail packaging actually gives the bore size right on the package somewhere.
For driving you need a bolt and nut that matches the insert's internal thread. Run the nut up the bolt about the same distance as the insert is long. Now thread the insert onto the bolt up to the nut. Now you can use the bolt to drive the insert home. If you are concerned about the nut marring your wood surface just put a flat washer between the nut and insert w/ a nylon frictionless washer under that washer. The insert will auto flush w/ the washer arrangement but will not rotate on the surface of the wood. Once the insert is seated just loosen the locknut and reverse the bolt out of the insert and you're done.
Notes/tips:
After you drill the hole, use a chamfering bit to slightly ease the edge. This allows the insert to start easier..
paraffin wax the insert before inserting.
Prethread w/ a lag bolt that has the tip ground flat to cut threads for the insert for really dense wood...
For normal situations prethreading is not necessary..
Hole diameters for hard and soft woods are usually different. Soft being the smaller pilot hole
Insert thread designs are often different for hard or soft woods. End and face grain, likewise.
Remember, you can always make a hole larger.
Adding adhesive is a good idea. It makes the threads cut into the wood stronger.
Buy a few extras and practice on some scrap.
Knowledge Base & Engineering Resources
Stick486 is offline
post #8 of 18 (permalink) Old 01-28-2019, 09:30 AM
Groan....
Sticky????
Stick486 is offline
post #9 of 18 (permalink) Old 01-28-2019, 10:06 AM Thread Starter
Stick in the house!!! AGAIN ��
post #10 of 18 (permalink) Old 01-28-2019, 10:27 AM
Originally Posted by sawdust74 View Post
stick in the house!!! Again ��
you asked....
Stick486 is offline
Router Plate inserts SteveMI Table-mounted Routing 14 08-02-2013 08:41 AM
Inserts necessary? spor Table-mounted Routing 5 07-11-2011 11:06 AM
Threaded Inserts Kelly Rittgers Jigs and Fixtures 20 11-24-2010 03:32 PM
Making a table: T-nuts OR threaded inserts? loninappleton Table-mounted Routing 7 07-14-2010 04:54 PM
MLCS/Harbor freight router plate inserts not flush with plate Mike Gager Table-mounted Routing 14 12-22-2009 09:54 PM
