Turning a Hole into a Slot - Router Forums
 18Likes
post #1 of 23 (permalink) Old 01-28-2019, 10:11 PM Thread Starter
RickKr's Avatar
Default Turning a Hole into a Slot
I've made a loom for making twined rag rugs for daughter (see below). It has a couple of braces on the sides to hold the frame at angles for access during weaving. I made the braces with 1/4+" holes for 1/4-20 hardware.
But now want to modify this arrangement to make the adjustment positions slots rather than holes. And I probably want the openings of the slots to be wider than the bottom.
I'm wondering what is the best way to open these up. Do a full width plunge with a 1/4" router bit, using a miter gauge to impart a little bit of angle and flipping it around to give the other side some angle? Or bandsaw out the middle and do the above as cleanup passes with the router bit on both sides?
Nominally, I would do the latter, because bandsawing is easy and to minimize the amount of cutting the router bit has to do. But, sometimes, cutting tools like to have nice full bites. Also, I'm thinking the free-hand/miter gauge router passes may be easier to control taking just a little bit.
Thanks,
Rick
Name:	Unfinished Rug Loom 640 01-15-19.JPG
Name:	Rug Loom Frame Brace 01-28-19 640.JPG
Name:	Rug Loom Brace Slot 01-28-19 640.jpg
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
post #2 of 23 (permalink) Old 01-28-2019, 11:14 PM
I would set the desired angle on my table saw but it doesn't look like you have one so If you need accuracy then an angle jig on one of the bandsaws. If not necessary to be really accurate then just draw what you want and free hand it.
harrysin likes this.
post #3 of 23 (permalink) Old 01-29-2019, 12:44 AM
I think I'd use a Japanese saw. I'd make a small jig like the drawing in a trapezoid shape with the angle you want for each cut, with a small block on the back to hold it in place while making the cut. I'd make the front out of at least half inch hardwood scrap so it will resist being cut in the process.
Hold the dozuki style saw (with the rigid back) as you would a chef's knife, a finger on the side to keep it from shifting on you, then place the saw against the edge of the jig and probably less than 4 pulls and it will cut through, making an extremely smooth edge.
By the time you set up a saw or router to do this cut, you could be finished with the Japanese saw. If you don't yet have a Dozuki saw, you have no idea what you're missing. Once you use it you will reach for it often, cutting is like slicing butter. Here are pictures of the two types of Japanese saws. The first has no backer, the second shows three types with backers. I like the longer saw best Amazon. About $35 as I recall. You can't have these sharpened, so when it gets too dull to use (that will take a long time judging from mine), you replace the blade part with a new one by clipping it into the backer. The backer keeps the blade ridgid and that's the one to get.
My 2 bits.
Name:	dozuki cut guide.jpg
Name:	Japanese pull sawc.jpg
Name:	Japanese Dozuki pull saws.jpg
kp91, thomas1389 and sreilly like this.
post #4 of 23 (permalink) Old 01-29-2019, 09:05 AM
Honored Member
harrysin's Avatar
First Name: Harry
What's wrong with a jig saw???
Harry
harrysin is offline
post #5 of 23 (permalink) Old 01-29-2019, 12:58 PM Thread Starter
RickKr's Avatar
Originally Posted by DesertRatTom View Post
I think I'd use a Japanese saw. ...snip...
My 2 bits.
Interesting. I've never used a Japanese saw, but I have been a bit curious lately. Not likely I'll be patient enough to order one in time for this project, but thanks for the nudge.
Rick
RickKr is offline
post #6 of 23 (permalink) Old 01-29-2019, 01:07 PM
Nickp's Avatar
First Name: Nick
In a pinch, there are plenty of hand tools that will do the job...hand saw, miter box saw, jig saw, hacksaw (coarse tooth), pull saw, even a sheetrock saw, etc... Then there's scroll saw, coping saw...oscillating tool plunge cut...
...and probably lots more ideas...
Mind you, there is always a reason to go get another tool.nature of the game...
kp91 likes this.
Nick
Nickp is online now
post #7 of 23 (permalink) Old 01-29-2019, 01:12 PM Thread Starter
RickKr's Avatar
Originally Posted by Nickp View Post
... snip...
Yes, I am a charter member of that club, as my daughter will attest as I fill the garage with more tools.
Rick
RickKr is offline
post #8 of 23 (permalink) Old 01-29-2019, 01:14 PM
Nickp's Avatar
First Name: Nick
Rick
...and if you're a Tim Allen type, there's always the chain saw in the garage...
Herb Stoops likes this.
Nick
Nickp is online now
post #9 of 23 (permalink) Old 01-29-2019, 01:38 PM
Nickp's Avatar
First Name: Nick
Rick...on a serious note...whatever tool you decide to use, keep in mind that you might create some tear out since you're cutting end grain. Probably not an issue as you'll likely round the edges a bit anyway. If you use the bandsaw you might want to use a blade that has a higher tooth count so you don't tear the bottom. Slight tear out can be sanded but you wouldn't want to chip out a sliver.
For the design, you might not need to cut it wider at the entrance as a bit of rounding on the face edge will allow for easy entry. I would angle the cut to the hole at the same angle as the expected entry angle...this might help to keep it more stable under use.
Good luck...pics are always nice...
Nick
Nickp is online now
post #10 of 23 (permalink) Old 01-29-2019, 01:49 PM
I am assuming you don't want to have a rough edge or splintering since yarn of some sort will be pulled through the gap and you don't want snags. The Japanese saw produces a baby butt smooth cut without tearout. The jig isn't necessary, but being something of a fuss budget, I would want the cuts to look and be uniform. You could get the Dozuki saw from Amazon in a day or two. Lowes has an Irwin pull saw that's about half the price of a Japanese saw, but it doesn't have the stiffener. But pull saws don't bind, so it might not matter. The saws have about 22 teeth per inch, slightly more than 1mm each.
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
Hole Tolerance using a Hole Saw Kevin Witt New Member Introductions 11 07-17-2014 09:21 PM
Slot cutter question schmoo Router Bits - Types and Usage 5 04-09-2012 08:04 PM
Slot cutting bit for luan plywood ccmnova Router Bits - Types and Usage 1 06-09-2011 06:24 PM
Mitre slot : straight or T-slot? matt1710 Table-mounted Routing 5 05-10-2011 10:55 PM
