Tread to Housed Stringer on Ladder (Dowel vs Screws) - Router Forums
 17Likes
post #1 of 24 (permalink) Old 01-29-2019, 10:27 AM Thread Starter
jb9
Default Tread to Housed Stringer on Ladder (Dowel vs Screws)
Hello,
I am working on building my first ladder. It is a small ladder for access to a crawl space. My material is all douglas fir 2x. My stringers are 2x8 and my treads are 2x6. I ripped a bevel into my 2x6 treads to match the pitch of the ladder. I am preparing to attach the treads to the housing I routed in my stringer and a very experienced cabinet maker is encouraging me to use angled dowels (+ epoxy) rather than screws (+ glue). I have some very high quality GRK RSS Structural Screws (5/16" x 4") which have a shear strength of 2900 lbs. I know this debate is a long-standing one but I just can't wrap my head around why an angled dowel (with epoxy of course) would be a stronger connection than 2 of these GRK structural screws. Part of my hesitation probably lies in my lack of experience in drilling the angled holes for the dowels but I'm curious to learn more. I do think the dowels would be much more aesthetically pleasing but I do think when people talk about the inferiority of screws they don't always take into account some of the modern high-quality structural screws that are now readily available. It's as though people think screws and they immediately think you are using drywall screws.
Anyhow, there are so many knowledgeable pros here I figured I would ask.
Thanks in advance for any thoughts.
jb9 is offline
post #2 of 24 (permalink) Old 01-29-2019, 10:57 AM
Nickp's Avatar
First Name: Nick
No doubt the GRK's will be stronger...but you also need to consider width of the ladder and if there will be any side-side sway. Glue might also be problematic if the crawl space is exposed to the elements (humidity, etc). Also keep in mind that you're screwing into end-grain...be even more careful if the wood is pressure treated and still wet.
If you're using the ladder in a visibly pleasing space you might consider better wood but I''m thinking that's not the case.
Assuming that is true, I would also include a stretcher from stringer to stringer to pull them together (like attic stairs have). 1/4" threaded rod should do.
You might want to describe the environment around the ladder and more of it's specs...you might get better or different ideas...
Good luck and welcome to the Forum...
Nick
Nickp is offline
post #3 of 24 (permalink) Old 01-29-2019, 11:16 AM
under stress endgrain fastening is a lost cause before you even get started...
how I'd do it...
mortise the steps into the stringers about 3/8''....
L/R strings connected together w/ all thread centered under the stair....
fender washers, lock nut, cap nut assembly on the outside of the stringers ..
cap nut acts a a jamb nut and to protect you from bleeding...
the stair bottom grooved to receive the all thread is an option...
the block between the all thread and step bottom increases the step's capacity and controls under load flex/sag...
this method allows you to keep the stairs ''tight'' for they will loosen over time......
gmercer_48083 likes this.
Stick486 is offline
post #4 of 24 (permalink) Old 01-29-2019, 11:56 AM Thread Starter
jb9
These are all helpful suggestions. Thanks. The crawlspace is fairly well-insulated and should be dry (high desert climate). I do agree that the endgrain does pose a problem. The ladder is only 63" long with 5 treads and the side-to-side sway issue should be limited since it will be placed in a trap door opening. I have attached a crude annotated drawing of the trap door/ladder location.
jb9 is offline
post #5 of 24 (permalink) Old 01-29-2019, 01:18 PM
Stick's suggestions are excellent. A 2x construction will be very heavy if you are going to have to lift it out of the way, so 1x construction in a decent hard wood is probably a much better choice. What you are describing is more of a stair way than a ladder. Using lighter, higher quality, kiln-dried material will make it easier to fold the ladder up into the ceiling, a desirable quality for a space you may want to reach only occasionally.
You can buy commercially made folding, retractable ladders built just for this purpose. You cut out the ceiling between stringers to create the space, screw or bold the ladder assembly into the sides of the stringers and you're done. Unless you are carrying 100 lb items up and into the crawl space, one of these should do the trick. Or, at least study one and duplicate it.
Notice the metal plates connecting the 3 sections of the ladder. Each allows the next section down to fold up onto the higher section. This gives you a stak of three sections that fit into the recess. The run from about $350 to about $450 at Lowes. They are made of better quality wood and include trim to make it look nice.
Part of the price is for the liability involved with any ladder. If someone climbs a Werner ladder, for example, Werner faces the lawsuit. Who will face the music if someone slips on your ladder, or it separates and collapses on someone? With ladders, liability is a consideration. For example, what about if you have a person come in to replace the attic fan, or add or repair wiring, or handle a gas or water pipe leak, or movers coming in to clear out the stuff up there?
At least go and check out the commercial models.
post #6 of 24 (permalink) Old 01-29-2019, 01:35 PM
I had some steel risers for front step in one place I lived in. It used 2 x 6 for treads which were screwed to the risers with number 8 screws. The screws kept shearing off. The vibration when walking on them work-hardened the metal of the screws and made them brittle. You are using a much larger shank screw and it will see less traffic but it`s something to keep in mind. I try to avoid using screws for framing now because of that experience. Walls move so there is a chance the screws may shear off one day whereas a nail never will.
My favorite nail is a phosphorus coated box nail. Even in end grain once they seize up they can be extremely hard to pull out. And if you add risers to the steps, even narrow ones that just go a couple of inches below the treads that will help prevent any side to side movement that would tend to loosen the fasteners. Otherwise I would add a couple of threaded rods as already suggested.
DaninVan and Danman1957 like this.
post #7 of 24 (permalink) Old 01-29-2019, 01:47 PM
JOAT's Avatar
First Name: Theo
My first thought was, stepladder. Would be useful many other ways as well.
mgmine likes this.
JOAT is offline
post #8 of 24 (permalink) Old 01-29-2019, 01:48 PM
I think he is doing a crawl space, Tom.
Herb Stoops is offline
post #9 of 24 (permalink) Old 01-29-2019, 03:55 PM
Thanks Herb for the correction.
post #10 of 24 (permalink) Old 01-30-2019, 10:28 AM
roxanne562001's Avatar
First Name: Roxanne
I am with Stick on this one.
roxanne562001 is offline
Housed Stringer Question jb9 General Routing 3 01-19-2019 09:05 PM
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
Ladder accident chessnut2 Shop Safety 47 01-27-2014 08:12 PM
Quick attic ladder Doctor Atomo Show N' Tell 10 03-24-2012 07:46 PM
