Routing convex on ends and one edge of same board - Router Forums
 4Likes
  • 1 Post By Stick486
  • 1 Post By Cherryville Chuck
  • 1 Post By Boberto
post #1 of 7 (permalink) Old 01-30-2019, 05:13 PM Thread Starter
First Name: Bob
Default Routing convex on ends and one edge of same board
It's been a while since I've done this. What is the correct way to do this. Ends first or edge first? One way will take out any tear out of the other but I don't remember which.
Boberto is offline
post #2 of 7 (permalink) Old 01-30-2019, 06:28 PM
End grain 1st...
harrysin likes this.
post #3 of 7 (permalink) Old 01-30-2019, 06:54 PM
Nickp's Avatar
First Name: Nick
Sounds like you're not going to do anything with the 2nd face...
If that is the case you might want to do a small climb cut on the 2nd end grain cut as you won't have the 2nd face to clean it up. If so, do the climb cut on the corner of the 2nd end grain cut that is away from the face you will cut.
So if your board is standing up and down with the end grains at North and South and the face to be cut at West, cut North first, then West, then climb the Southeast corner, then cut South. The entire direction would be counterclockwise except for the climb cut. (assuming handheld)
If I got it wrong, then do exactly what Stick said...end grain first, long face, end grain, long face last.
What profile are you cutting and are you cutting freehand or table...?
Nick
Nickp is offline
post #4 of 7 (permalink) Old 01-30-2019, 11:15 PM Thread Starter
First Name: Bob
Sorry, I should have explained a bit more.
I am working on the mission mantle clock from Klockit. The top plate and bottom plate have convex profiles on the ends and front- 3 edges of the 4 need this convex. The back does not. Just on one face of each board. I am attempting to do this on my router table with a Bosch 1617evs router. Thanks for your help.
Bob
Boberto is offline
post #5 of 7 (permalink) Old 01-30-2019, 11:34 PM
route the end grain 1st using a sacrificial board to avois tear out...
File Type: pdf woodsmith-184-avoiding-router-table-tearout.pdf (292.2 KB, 19 views)
sreilly likes this.
post #6 of 7 (permalink) Old 01-31-2019, 03:29 AM
Or use a push block to push the board past the bit as shown in this video at the 5 minute mark: https://www.youtube.com/watch?reload=9&v=hHnLvps8968
I usually just grab a leftover piece of ply or mdf that's from 6-10 inches square and use it to push my work through. That keeps it square and and reduces the chance of blowout to near zero. Clamping the board to your work is about 99%+ foolproof.
TenGees likes this.
post #7 of 7 (permalink) Old 02-01-2019, 07:05 AM Thread Starter
First Name: Bob
Thanks for your help. I got it done with a sacrificial push block like you suggested. It worked out great.
Cherryville Chuck likes this.
Boberto is offline
