Mirror Template - Router Forums
 20Likes
post #1 of 14 (permalink) Old 02-01-2019, 04:16 PM Thread Starter
Ed3443's Avatar
First Name: Ed
Default Mirror Template
I would like to mount a frameless mirror to a piece of MDF or plywood using mastic. Then, I would like to use the mirror as a template using a bearing router bit. Will this work? Will I break the glass? Should I tape the edges before trying this? Or is this just a really stupid idea? Thanks!
Ed3443 is offline
post #2 of 14 (permalink) Old 02-01-2019, 04:49 PM
kp91's Avatar
First Name: Doug
One of the early Router Workshop videos was inlaying a ceramic tile using a bushing guide inlay bit. I don't know if the edge of your mirror is thick enough to guide a bearing and accommodate the little gap between the bearing and the cutters.
I would trace the mirror, cit with a jigsaw and sand to the line.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 14 (permalink) Old 02-01-2019, 05:04 PM
you will break the mirror from resonation alone.....
listen to Doug..
Ed3443 likes this.
post #4 of 14 (permalink) Old 02-01-2019, 07:56 PM
JOAT's Avatar
First Name: Theo
Totally agree. I make all my masters that way, except I cut almost all of them out with my scrollsaw. I only use a jigsaw on the larger masters, such as a 4' cigar store Indian. I use a ROS on them, and the final product is very accurate.
DesertRatTom and Ed3443 like this.
JOAT is online now
post #5 of 14 (permalink) Old 02-02-2019, 07:36 AM
First Name: Art
I would try it on a scrap piece and see if it works. The only thing I would nemtion is to besure that you're using the correct mastic for mirrors. You can get around the possible chipping by removing the bearing and placing a very thin shim or washer under it. You won't be able to router to the very edge of the mirror doing it this way but there will be only a small lip to sand off. Is your final objective to leave the mirror as is or are you going to be using it as a pattern for something else?
mgmine is offline
post #6 of 14 (permalink) Old 02-02-2019, 08:47 AM
Gene Howe's Avatar
First Name: Gene
I've done it with 1/4"tempered glass but, a thinner, untempered mirror would be problematic. Other's suggestions of cutting and sanding to fit would be best.
Ed3443 likes this.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #7 of 14 (permalink) Old 02-02-2019, 09:01 AM Thread Starter
Ed3443's Avatar
First Name: Ed
Thanks Everyone. I appreciate all the feedback. This forum is so great for newbies. Thanks again
kp91 and Roy Drake like this.
Ed3443 is offline
post #8 of 14 (permalink) Old 02-02-2019, 09:23 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
One more word of caution, from somebody who did that and got the T shirt....
I stuck a small mirror inside a jewellery box using a dab of two part epoxy and its SHOWED right through the mirror! I had to break the mirror out and fit another using double sided tape across the whole surface so there werent any bad marks showing through the glass.
But apart from that, DONT use a mirror as a template, oh no oh no ho no.
kp91, Gene Howe, MEBCWD and 1 others like this.
sunnybob is offline
post #9 of 14 (permalink) Old 02-02-2019, 10:15 AM
Gene Howe's Avatar
First Name: Gene
Bob, thanks for the word of caution. Didn't know epoxy would eat through the mirror silvering. Must be more caustic than I thought.
Gene Howe
Snowflake, AZ
post #10 of 14 (permalink) Old 02-02-2019, 10:58 AM
Not all DB tape is the same, I have had some turn gooey over time and release the part. I am not sure which one to recommend, as I don't use them for permanent attachment anymore. It might be best to call a glass outfit and have them recommend the best adhesive.,
Just saying,
Ed3443 likes this.
Herb Stoops is online now
