Removing Plastic Protective Coating on Bits - Router Forums
 22Likes
post #1 of 36 (permalink) Old 02-11-2019, 02:41 PM Thread Starter
Steven Owen's Avatar
First Name: Steven
Question Removing Plastic Protective Coating on Bits
I notice the bits Iíve ordered from Infinity tools come with a clear plastic coating on them for protection in shipping. What is the best method for removing the plastic protective coating from router bits?
I love to make pretty things for pretty little things
Steven Owen is offline
post #2 of 36 (permalink) Old 02-11-2019, 03:23 PM
Is this the same rubbery stuff that carbide saw teeth are dipped in? In the case of the saw teeth, I know guys that leave it on, mount the blade, and make a cut in scrap wood. Problem solved...apparently. :0
DaninVan is online now
post #3 of 36 (permalink) Old 02-11-2019, 05:58 PM
I usually peel off the protective coating with a thumbnail. I don't know if the coating on Infinity bits is any different than anyone elses bits.
post #4 of 36 (permalink) Old 02-11-2019, 06:37 PM
JOAT's Avatar
First Name: Theo
Pocketknife does it for me.
hawkeye10 likes this.
JOAT is offline
post #5 of 36 (permalink) Old 02-11-2019, 06:39 PM Thread Starter
First Name: Steven
It should be. You canít run a router bit and remove it that way because it can damage the bit. I know some people use a utility knife to gentely remove it. Always thought there would be a liquid or spray you could apply to dissolve the coating.
post #6 of 36 (permalink) Old 02-11-2019, 10:25 PM
I've heard that you can collect and reheat and reuse it but have never tried it. That would imply that it can be melted off with a heat gun.
post #7 of 36 (permalink) Old 02-12-2019, 12:15 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Every one I have ever has been so soft it can be peeled off with a thumbnail in seconds.
JFPNCM and gaftech like this.
sunnybob is offline
post #8 of 36 (permalink) Old 02-12-2019, 06:25 AM
Yup -- the peeling thing works for me too.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #9 of 36 (permalink) Old 02-12-2019, 06:26 AM
ger21's Avatar
First Name: Gerry
Sometimes the rubber can be fairly hard.
I use a small awl, and slide it down the inside of the flute from the shank end. After that, it'll usually pop right off in one piece.
Ger
www.cncwoodworker.com
ger21 is offline
post #10 of 36 (permalink) Old 02-12-2019, 09:15 AM
sreilly's Avatar
First Name: Steve
Depending on the cutter I would either peel from the shaft down to the cutter keeping in mind the cutter are sharp. It's the same coating that comes on Forest blades and intended as a protective covering. On my rail and stile set from Whiteside (they also use this coating) it came off is several pieces. Trying to make a cut with it intack is foolish in my opinion. You don't want stuff flying around the shop and that would come off in pieces and be flung at the speed of the router. Seems reckless to me.........but that's just me.
sreilly is online now
Mortising bits vs straight bits oldskeetshooter Router Bits - Types and Usage 10 12-24-2017 05:20 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Removing Bits from PC 890 Router esears1 Starting Off 5 03-10-2006 11:27 AM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
