A bit of help with a R181FB router - Router Forums
 1Likes
  • 1 Post By vchiarelli
post #1 of 9 (permalink) Old 02-17-2019, 04:08 PM Thread Starter
Unhappy A bit of help with a R181FB router
I am having trouble with my router. The locking bar keeps coming loose and the set depth is moving while I am using it. Please advise. I don't know what I missed when setting it up. I read and reread the users manual and still I just routed through my work table.
kathaap is offline
post #2 of 9 (permalink) Old 02-17-2019, 04:58 PM
vchiarelli's Avatar
First Name: Vince
@kathaap - welcome to the forums - there should be a bolt/nut combination that holds your "locking bar". You may have to tighten the nut to offer more resistance when you lock the bar in place. I'm guessing that there isn't enough resistance there. When you lock the bar in place, how much tension is required?
If you can post a picture of your router, we may be able to offer more assistance. You cannot post any links to websites until you've reached 10 posts, but you can post pictures from your computer. BTW, please update your profile and supply a first name - makes for more personal interaction.
Herb Stoops likes this.
vchiarelli is offline
post #3 of 9 (permalink) Old 02-17-2019, 04:59 PM
kp91's Avatar
First Name: Doug
I will try to look for a drawing online, but there should be a screw you can turn to tighten up the clamp. This will increase the clamping force on the base.
I don't know if the nut inside the highlighted circle can be turned, but that is where I would start
Name:	ryobi parts.JPG
kp91 is online now
post #4 of 9 (permalink) Old 02-17-2019, 08:29 PM
Nickp's Avatar
First Name: Nick
On page 8 of your manual there is a blow up bubble diagram showing the Locking Arm...there is a small nut on the other side of the Locking Arm. That nut can be tightened/loosened to provide the right amount of locking arm pressure when pressed against the body of the router.
Assuming that might be your problem, try going in a half turn at a time until you get a solid lock.
Nick
Nickp is online now
post #5 of 9 (permalink) Old 02-17-2019, 10:16 PM
JOAT's Avatar
First Name: Theo
Are you bottoming your bit?
JOAT is online now
post #6 of 9 (permalink) Old 02-18-2019, 01:30 AM Thread Starter
Thank you all for your help. I tightened the nut under the locking bar and so far so good. I’ve got some more to do tomorrow. If the problem isn’t corrected I’ll be back. 😊
I ended up with a 1/2” hole in my work table today. That’s why I ended up joining this forum. Thank you again! I have at least two more projects in the near future that also need some work with a router and it’s been years since I last used one.
kathaap is offline
post #7 of 9 (permalink) Old 02-18-2019, 07:07 AM
kp91's Avatar
First Name: Doug
Glad to hear it! Good luck on the projects
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #8 of 9 (permalink) Old 02-18-2019, 07:50 AM
Nickp's Avatar
First Name: Nick
Good to hear you're back in business...
Nick
Nickp is online now
post #9 of 9 (permalink) Old 02-18-2019, 09:36 AM
sreilly's Avatar
First Name: Steve
Originally Posted by kathaap View Post
Thank you all for your help. I tightened the nut under the locking bar and so far so good. Iíve got some more to do tomorrow. If the problem isnít corrected Iíll be back. 😊
I ended up with a 1/2Ē hole in my work table today. Thatís why I ended up joining this forum. Thank you again! I have at least two more projects in the near future that also need some work with a router and itís been years since I last used one.
Well welcome to the forum and sorry about the hole. Looks like a reminder for the future like many of us have in our shop. But now that you're here you may want to look around and see what else is likely to peak your interest. There are plenty of resourceful and skilled woodworkers here willing to share their knowledge and answer questions.
sreilly is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 05:18 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
