Skil 1825 - Replacement Collet or Adapter? - Router Forums
 3Likes
post #1 of 13 (permalink) Old 02-18-2019, 01:39 AM Thread Starter
Default Skil 1825 - Replacement Collet or Adapter?
Hi all,
New to the forum, primarily in search of a little help. I have the aforementioned Skil 1825, and I'm finding that the 1/2" to 1/4" collet adapter either doesn't hold the bit tightly enough, or I have to crimp it on so hard with channel locks that I can't get the bit out without putting a screwdriver in the slot. I think part of my learning process was to try to go too deep on a single pass, and as a consequence the adapter would slip and the bit rise up, and somewhere along the way the adapter has become badly scored or maybe just out of round.
I thought I'd simply replace the adapter with a new one, so bought a generic one from a local supplier. It fits in the collet, but try as I might it won't tighten, either in the router or with the channel locks. So I'm left wondering if there's a requirement for a Skil 1825-specific replacement - there's one on Amazon.ca at $58.90, which strikes me as less than a good deal. Alternatively, could I just replace the entire collet with a 1/4" one and not need an adapter? I have only a couple of 1/2" bits, so no great loss.
Question then is, can I replace the entire collet, and if so, is there a Skil-specific replacement, or could I use someone else's version? If I can't replace the whole thing, is there an alternative to spending $58.90 on Amazon? I've searched both local sources and the web with no success to date.
Any suggestions gratefully received!
Spiggy Topes is offline
post #2 of 13 (permalink) Old 02-18-2019, 06:50 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Welcome to the forum.
Did you try E-replacement parts?
I think this is what you're looking for:
https://www.ereplacementparts.com/co...-p-119346.html
smitty
smitty10101 is offline
post #3 of 13 (permalink) Old 02-18-2019, 06:57 AM
Nickp's Avatar
First Name: Nick
...you may know this already but do not bottom the bit; put it all the way in and then raise it about 1/8". This will make sure the bit does not bottom as you tighten it and stopping the collet/adapter from doing it's job. The bit will move towards the router as you tighten it...give it a bit of room...
TenGees likes this.
Nick
Nickp is offline
post #4 of 13 (permalink) Old 02-18-2019, 07:58 AM
sreilly's Avatar
First Name: Steve
Welcome to the forum. The care and use of a router needs careful study before using it for the first time. Stick will likely post with some very good information that should be required reading. Bit placement and speed are extremely important. As you've already been advised, if you didn't know already, inserting the cutter all the way and raising it slightly is the proper method of installation. It makes a big difference and is a safety concern as well. Don't try to make a cutter deeper by moving it out near the end of the shaft, get a longer or more appropriate profile cutter. Much more advice and concerns will follow with PDFs and the such to help you along. For now I'd look at the link above for the ereplacements chuck and get at least the original chuck made for that tool. If you use 1/4" cutters then install the 1/4" collet, use the 1/2" for 1/2" bits.
sreilly is offline
post #5 of 13 (permalink) Old 02-18-2019, 09:22 AM
Collets are really precision devices. A they really tighten only a fraction of a mm. I'd try ereplacement parts--they have a lot of stuff. I'd also contact Skill to ask whether they have the part.
post #6 of 13 (permalink) Old 02-18-2019, 02:38 PM
TenGees's Avatar
First Name: Paul
Personally, I wouldn't use channel locks on a collet. Some collets, once loosened, need to be loosened more. As you loosen further you feel resistance again and that is when it is letting go of the bit (no need for a screwdriver). As has been mentioned: Make sure the bit isn't bottomed out, when tightening it.
TenGees is offline
post #7 of 13 (permalink) Old 02-18-2019, 04:19 PM
Hypnotoad's Avatar
First Name: Phillip
If you can get hold of these they are magic, I don't use any other type of reducer now these are so good:
https://www.routerforums.com/general...ml#post1976773
Tight fisted old so-and-so!
Hypnotoad is offline
post #8 of 13 (permalink) Old 02-18-2019, 05:04 PM Thread Starter
I did some further digging. Couldn't find anywhere in Canada, but did find "Bosch/Skil Adapter #BSH-1619X03843" on partswarehouse.com, so I ordered three. So many sites won't ship to Canada still, and the Canadian sites for Walmart and Newegg carry much less inventory than the US equivalents. Never thought I'd find such things on Newegg, of all places. So, a couple of weeks until they get here and I should be good to go again. Thanks for the suggestion.
post #9 of 13 (permalink) Old 02-18-2019, 05:13 PM Thread Starter
I wouldn't have used channel locks if there was any other way. It seemed to be the only way I could the bit not to slip, but then I'd have to use the screwdriver pressed clockwise whilst rotating the bit anti-clockwise to get it out again. Even resorted to positioning over a vise and using a nail to hammer out a very narrow bit on a couple of occasions. Needless to say, I'm not entirely proud of my methods to date. I'll see if I can fare a little better with new, un-abused collet adapters.
TenGees likes this.
post #10 of 13 (permalink) Old 02-18-2019, 05:20 PM Thread Starter
Yup, thanks to all for the advice, and I'll take a little more care of all aspects from here on in. As to 1/4" collets, rather than adapters, just how exchangeable are they? This router has a plate that can be pushed in to immobilize the motor, which implies flats at the base of the collet, and I have no idea if that's a common thing or not. I've yet to find a 1/4" collet specific to this router - I think one site listed one as outdated, no replacement available, none in stock, but that's the closest I've come. There are Bosch collets available, but I don't know if they'd work with this router.
1/4 Collet Adapter Stuck codycoyote General Routing 5 01-01-2016 11:28 AM
Wanted: Skil 1825 router collet nut gertmcfly Woodworking Classifieds 0 12-14-2011 06:44 PM
Craftsman Quickrout 1/2" collet adapter lwbox CNC Routing 7 05-01-2011 09:56 PM
8mm collet adapter vs 8mm collet toddpolo14 Tools and Woodworking 22 11-21-2010 08:25 AM
Skil 1825 quarter inch collet problem arde New Member Introductions 9 06-21-2009 05:40 PM
