Anyone ever cut a slot in schedule 40 PVC pipe? - Page 5 - Router Forums
 38Likes
post #41 of 49 (permalink) Old 04-07-2019, 01:46 PM
Nickp's Avatar
First Name: Nick
Duane...it would be very helpful for steering if you had some of the rudder (about 10% to 15%) sticking through the shaft. This will allow the forward motion to help steer when you turn the rudder. If you didn't glue it to the shaft, just drill new holes further back...
Nick
Nickp is offline
post #42 of 49 (permalink) Old 04-07-2019, 01:49 PM Thread Starter
Duane Bledsoe's Avatar
First Name: Duane
Originally Posted by RickKr View Post
WOW! Eight rod holders for up to two people <a href="http://www.routerforums.com/images/RouterForums_2015/smilies/tango_face_surprise.png" border="0" alt="" title="EEK! Surprise!" >:-)</a>
Attached is an image for a table saw sled for holding bamboo for cutting a full-length, straight slot, as the first step in bandsawing strips for further processing into bamboo fly rods. The bamboo is held down by elastic bands. I think this may be similar to some of the suggestions you've received. This one is kinda fancy, but I'm sure you could build something more utilitarian and specific to your needs.
I have one of these, but have not used it yet. I only recently bought a table saw, so I could not have used the sled previously. My activities in making bamboo rods are "in remission" until my daughter/granddaughter move out, freeing up space in my shop/garage.
Rick
The idea is each person brings 3 rods. One in your hand and two stowed behind you. This uses one 4 rod rack and leaves the other empty, and that is the side you fish from. When you switch sides, move the rods to the other rack.
Duane Bledsoe is offline
post #43 of 49 (permalink) Old 04-07-2019, 01:53 PM Thread Starter
First Name: Duane
I only built it to control rotation when adrift. It's hard to fish a shore when the boat twists around. I use the motor for steering.
post #44 of 49 (permalink) Old 04-07-2019, 02:15 PM
Nickp's Avatar
First Name: Nick
Gotcha...but now you have me wondering - if you are drifting, basically standing still in water, how does a rudder work for you when there might not be enough movement for steerageway...? Are you concerned more what wind will do to the boat when fishing a shoreline...? Not criticizing your work or idea, just personal wondering...
Nick
Nickp is offline
post #45 of 49 (permalink) Old 04-07-2019, 03:44 PM
MT Stringer's Avatar
I like the boat. At one time, I loathed over a similar set up I saw at a store near our local reservoir. A guy had it all rigged up for bass fishing. I have some of the same rods and reels (or close to it). That would make a good stable platform for flats fishing in and around Galveston west end/marshes. Probably use the same bait!
Not trying to hijack, but here is my kayak from years ago (late 90's). The Stringermobile!
MT Stringer is online now
post #46 of 49 (permalink) Old 04-07-2019, 06:26 PM Thread Starter
First Name: Duane
These small boats are notorious for rotation. They say adding a rudder will help this, so I did it. My experience has been when fishing a shoreline and just letting the boat float or drift, the rear end of the boat tries to spin around and leaves the guy in back no way to cast towards shore. I have to constantly correct it with the motor. I figured this rudder will act the same as having a paddle in the water and resist the rotational turn the boat tries to do. All I'm doing with it is creating a drag when it tries to move or spin sideways, but not hamper forward movement, or reverse, which is why I built it to be retractable when in reverse. It won't get in the way when backing in close to shore, and it won't affect the steering either, if it is retracted. The motor does all the moving and steering. All the rudder has to do is keep the boat tracking in a straight line.
post #47 of 49 (permalink) Old 04-07-2019, 06:53 PM
Nickp's Avatar
First Name: Nick
gotcha...thanks...
Nick
Nickp is offline
post #48 of 49 (permalink) Old 04-13-2019, 09:10 PM Thread Starter
First Name: Duane
Pics of that rudder in action. It works like a champ!
MT Stringer and TenGees like this.
post #49 of 49 (permalink) Old 04-13-2019, 09:14 PM
Nickp's Avatar
First Name: Nick
Nice...many happy hours fishing...
Nick
Nickp is offline
Andrew from Cedarville, OH StrawHOC New Member Introductions 11 09-25-2017 10:54 AM
Hello from new forum member rodnre New Member Introductions 23 07-06-2017 10:01 AM
Newbie from Virginia 4alpha426 New Member Introductions 13 03-28-2017 01:40 PM
Need Help With 8" PVC Pipe tred1956 Portable Routing 20 05-25-2015 10:23 PM
thin wall pvc pipe problem timothy New Member Introductions 6 04-22-2008 11:02 PM
