Craftsman router - Router Forums
 21Likes
post #1 of 16 (permalink) Old 04-05-2019, 09:14 AM Thread Starter
Default Craftsman router
I have a gently used Craftsman 1 1/2 hp 315.1749 router. I have lost the collett. It takes a 1/4 inch. I have searched and searched, but cannot find a replacement. Every time I find anything, it says discontinued. Any help?
Dcook65 is offline
post #2 of 16 (permalink) Old 04-05-2019, 09:48 AM
OCEdesigns's Avatar
First Name: Chad
Here you go. I think this is what you need (The link has been fixed)
https://www.searspartsdirect.com/par...ch&q=300618002
Cherryville Chuck and Nickp like this.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #3 of 16 (permalink) Old 04-05-2019, 10:12 AM
There are no parts for those routers anymore. If you find the part it will be nothing short of a miracle so take good care of it. Chad's link keeps showing an error for me so I don't know if it will work for you and I would be surprised if they had one. We've seen a lot of people come through here trying to find a collet for that router. I have an old one that might be that model and is at least close to that model and the end of the armature was slotted and it was the collet. The inside of the shaft is worn and won't hold the bit anymore and the only cure I can see is replacing the armature. It was a bad idea that only saved a few dollars in the manufacture of it.
DaninVan, Nickp and RainMan 2.0 like this.
post #4 of 16 (permalink) Old 04-05-2019, 11:14 AM
My first router was an off brand. Not worth repairing, and parts just get harder to find. If you want to keep it and find a source, order a couple of both half inch and quarter inch so you have a spare. And if you find one, please let us know the source. It's nice to be helpful to the members who have one of these.
post #5 of 16 (permalink) Old 04-05-2019, 12:36 PM
OCEdesigns's Avatar
First Name: Chad
I fixed the link. Should work now. the part number you need is 300618002
post #6 of 16 (permalink) Old 04-05-2019, 12:53 PM
JOAT's Avatar
First Name: Theo
It does say they have it. At $55 and change.
JOAT is offline
post #7 of 16 (permalink) Old 04-05-2019, 01:08 PM
wingless's Avatar
Welcome to the forum.
There are not any parts available for those older routers.
Search eBay, Craig's List and Offer Up to locate / purchase an identical or equivalent replacement.
wingless is offline
post #8 of 16 (permalink) Old 04-06-2019, 07:20 AM
CharleyL's Avatar
First Name: Charley
Unless the router is special for some reason, it's usually better to just buy a new router than try to find parts for any router that is no longer in production. The new router will have many improvements over the older one, and in many cases won't cost that much more than having the old one repaired, if parts are even available to repair it. Soft start, plunge, and multi base capability make new routers much better than routers of only 20 years ago. One of my oldest routers is now cordless (I cut it off) and doing its new job as a door stop. It was a great router when it was new, but it is very obsolete when compared to today's routers.
Charley
Central North Carolina
CharleyL is offline
post #9 of 16 (permalink) Old 04-06-2019, 11:49 AM
Dcook65, another thing you should be aware of is that even if the collet is available and you pay $55 for it you'll still have a router that is only worth about $20 if you tried to sell it. Even though it has a brand new $55 part on it.
post #10 of 16 (permalink) Old 04-08-2019, 09:02 AM Thread Starter
Default Thanks for locating the part!
I have a PC fixed base/plunge router. I use the PC in my table. Thanks for the negative comments. I see no reason NOT to fix a usable router.
OCEdesigns likes this.
Dcook65 is offline
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Attaching a Craftsman router to a Porter Cable router table Vol1234 Table-mounted Routing 2 02-26-2012 01:00 PM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
