Wicked Fast Router Bit Organizer Trays - Page 2 - Router Forums
 29Likes
post #11 of 18 (permalink) Old 04-12-2019, 06:38 PM
JOAT's Avatar
First Name: Theo
Originally Posted by mimac View Post
You could make the dados sizes wider to stand the routers up in for storage
Nah, that would be work, and a waste of wood. The routers are all screwed to router plates, each router plate has a hole in it, and I hang them from nails in the rafters. They are out of the way, don't take up usable space, and easily available.
mimac likes this.
Of course I'm not busy, I did it right the first time.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is online now
post #12 of 18 (permalink) Old 04-13-2019, 09:04 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by JOAT View Post
Nah. I've got one each 1/2", 3/8", and 1/4" bits, all in routers. And one spare 1/2" bit in a drawer. Won't work for me.
In that case Theo I'd have difficulty making room for about 150 routers!
TenGees likes this.
Harry
harrysin is offline
post #13 of 18 (permalink) Old 04-13-2019, 09:30 AM
and I thought room for 50 was difficult...
TenGees and RainMan 2.0 like this.
post #14 of 18 (permalink) Old 04-13-2019, 10:34 AM
JOAT's Avatar
First Name: Theo
Nah, you're not thinking about it right. You hang the ones you aren't using from the rafters.
JOAT is online now
post #15 of 18 (permalink) Old 04-15-2019, 02:07 AM Thread Starter
First Name: Keith
As for these two concerns...
First is a spacing issue. It always seems that the uniform holes are either too close or too far apart, which eats up the space.
That's what brought me to the solution, so I could solve it by having the spacing all close together, which would have taken a lot of time with holes.
Second, is using a "hard" holder (wood, MDF, etc). The holes always seem to be too loose or too tight as use, temperature and humidity grows and shrinks the holes.
I've used my prototypes for over a year and the recommendations in the video are tried and tested to *not* be too tight or too loose. Humidity doesn't grow and shrink the wood enough to make a difference.
I rescued the cut off scraps from a foam rubber seller... (dumpster dove)
can't argue that price...
I feel like the availability can be argued with though - which dumpster can somebody go to to find these free scraps? The dado solution uses scraps without going dumpster diving. How long did it take you to assemble/glue the foam?
BTW - your idea of foam sounds like it would work great. I just don't see how it can be faster & cheaper for the typical woodworker.
keith204 is offline
post #16 of 18 (permalink) Old 04-15-2019, 02:09 AM Thread Starter
First Name: Keith
An excellent idea but longer and more difficult to make than holes.
wait... how on earth do you drill holes that fast?
In 5 minutes, I drilled the intersecting-dado equivalent of 384 "holes" for the Dremel bits tray. My entire solution is based on getting away from the time of drilling holes, so please do share how you drill holes so fast.
keith204 is offline
post #17 of 18 (permalink) Old 04-19-2019, 02:55 PM
First Name: AL
Talking A+
That is a great idea. Heading for the shop now.
Buce is offline
post #18 of 18 (permalink) Old 04-19-2019, 07:34 PM
RainMan 2.0's Avatar
And I thought you had the biggest router collection in the World . Looks like you may have been beat out
Hey but ya still got the USA
currently washed up
RainMan 2.0 is offline
Sears router bit description gary smyth Router Bits - Types and Usage 4 07-01-2011 05:15 PM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
