Bosch 1613/1617/1618/1619 collet dimensions - Router Forums
 1Likes
post #1 of 12 (permalink) Old 05-01-2019, 10:41 AM Thread Starter
Default Bosch 1613/1617/1618/1619 collet dimensions
I've got a Craftsman router that needs a new collet, and some online information suggests the Bosch collets may be the same size. From photos, they certainly *look* right.
I am wondering if some kind and helpful person could measure the collet thread (namely, the thread pitch and the outer diameter of the male part that the collet nut screws onto on the router) on one of the 1613/17/18/19 routers?
As far as I can measure, my Craftsman has an M20x1 thread.
arpruss is offline
post #2 of 12 (permalink) Old 05-01-2019, 01:27 PM
I don’t have access to mine right now but it was either 19 or 20 mm by 1mm thread pitch. I’m leaning towards 20 mm as the right diameter. It’s the same as a bunch of DWs, Hitachi m12V2, m12vc, m12ve, plus I think the newer Makitas. It is a very common collet but most Sears routers were made by Ryobi (315.xxxxx) and I haven’t seen any Ryobis with that collet but maybe the newer ones use it.
Herb Stoops likes this.
post #3 of 12 (permalink) Old 05-01-2019, 10:07 PM Thread Starter
Default arpruss
I donít have access to mine right now but it was either 19 or 20 mm by 1mm thread pitch. Iím leaning towards 20 mm as the right diameter. Itís the same as a bunch of DWs, Hitachi m12V2, m12vc, m12ve, plus I think the newer Makitas. It is a very common collet but most Sears routers were made by Ryobi (315.xxxxx) and I havenít seen any Ryobis with that collet but maybe the newer ones use it.
Thanks!
Online information seems contradictory. I found some information that suggested that the Hitachi M12 routers use 20mm thread, but at the same time Amazon has an off-brand collet for the Bosch routers that is explicitly listed as M19x1. So I would be really grateful if someone with a Bosch 1613/17/18/19 could measure their thread to see if it's 19mm or 20mm.
arpruss is offline
post #4 of 12 (permalink) Old 05-02-2019, 08:13 AM
I took the collet off my son’s 1617 and exchanged it with my V2 or VC. If you go to my uploads and look a few pages back there is a picture of me holding them end to end. They are identical. I just bought a pair of cheap Chinese made ones off eBay because one is a 12mm which I have a few bits for. They were either 10 or $12 for the pair.
post #5 of 12 (permalink) Old 05-02-2019, 10:30 AM Thread Starter
It's good to know that the M12V series has the same size as the 1617.
The ebay listings for the M12 collets have photos that says they are 20mm.
The Amazon listing for Big Horn collets that are supposed to be compatible with the Bosch 1617 (and other models) says it's M19x1.
For what it's worth I downloaded photos of Bosch collets and measured in Inkscape. One photo, from a repair site, had a nice top view with a 1" calibration grid. That gave me 19mm for the inner thread diameter, which corresponds to 20mm outer thread diameter, or M20. But unfortunately it was a low resolution picture so I am not confident I was measuring the right parts of it.
I also got a high resolution photo of the collet from Bosch's website. Unfortunately it was tilted, so I had to use trigonometry to estimate the tilt (24 degrees) and use a 1mm thread pitch to estimate the scale. This gave me 18.3mm inner diameter, which presumably corresponds to 19mm outer thread diameter, but there was no doubt a lot of error due to the use of thread pitch for calibration (hard to measure and need to correct for photo tilt) and perspective which I did not take into account.
arpruss is offline
post #6 of 12 (permalink) Old 05-02-2019, 11:23 AM
MikeMa's Avatar
Which model Craftsman are you working with? Craftsman has had a lot of different routers over the years, and have more or less relabeled other manufacturer's routers, including Bosch. With knowing what model router you have, you maybe have better luck getting the correct fitting collet for your router.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #7 of 12 (permalink) Old 05-02-2019, 05:16 PM Thread Starter
320.17541. I've done a lot of searching and the only 1/4" collets I can find for it are used ones for around $38 on ebay, which seems really expensive. Sears' parts store has the 1/2" collet, but the 1/4" is no longer available. I could get the 1/2" collet and then get a 1/2 to 1/4 reducer, but I am uncomfortable in using an adapter on something that spins so fast.
I destroyed my 1/4" collet when I got a 1/4" spiral cut bit stuck in it. The best online techniques for removing bits (wedging a U-shaped piece of wood, pulling with gloves) don't work on a spiral cut bit, and eventually the only thing I could think of doing was to cut the collet to save the router. :-(
arpruss is offline
post #8 of 12 (permalink) Old 05-02-2019, 06:39 PM
With a spiral you should be able to remove the nut over the bit. Then you can tap on the side of the collet and keep rotating it as you do and it will eventually release (as in 3-10 minutes). My M12V wasn’t available in 1/4” and came with a reducer which I’ve never had an issue with. If you purchased a Musclechuck for that router it would also need a reducer as the MC also only comes as a 1/2”. You can’t get a bit stuck in one which is why I switched my M12V2 to it to use in my table.
post #9 of 12 (permalink) Old 05-02-2019, 11:23 PM Thread Starter
The nut was getting stuck on a wider part of the collet cone that was sticking out of the nut. The only way I could remove the nut was by cutting off the part of the collet that was blocking the nut. :-(
arpruss is offline
post #10 of 12 (permalink) Old 05-03-2019, 08:28 AM
That’s odd. That lip is supposed to lock into a recess at the top end of the nut. In use you loosen the collet and spin it a turn or two at which point it will get tight again and need another turn with the wrench. When it loosens again it has pulled the collet free of the taper.
Bosch pof52 collet wanted Capetown dezza General Routing 3 03-14-2014 07:10 PM
Does the Bosch 1617 have a two wrench bit change collet? Duane Bledsoe General Routing 4 02-03-2014 03:22 PM
Bosch POF 40a nut and collet Pugdud General Routing 8 11-14-2013 03:32 AM
Will Bosch 1 3/8" OD bushing clear collet? Drew Eckhardt Guide Bushings and Templates 12 12-20-2012 06:51 AM
Bosch POF 1200 AE Collet Upgrade bramt General Routing 2 02-27-2012 12:47 AM
