Collet problem - Router Forums
 10Likes
post #1 of 18 (permalink) Old 06-10-2019, 05:31 PM Thread Starter
JimofSC's Avatar
Default Collet problem
I just purchased a RYOBI ONE+ 18V Palm Router for a project that I needed a cordless router and I didn’t want to break the bank on maybe a onetime use. Well the router works well for my project but changing the bits is not easy. The collet is ¼ “and my bits are ¼”. I have to drive the bits out of the collet every time and with different bits. I have a router table and two other routers and these same bits are not a problem. Any ideas what the problem may be?
Jim
Tega Cay, South Carolina
JimofSC is offline
post #2 of 18 (permalink) Old 06-10-2019, 06:46 PM
Does it have a collet nut that loosens then with further unscrewing it tightens where upon when loosened further with the wrench pops the bit free?
JFPNCM and TenGees like this.
Herb Stoops is online now
post #3 of 18 (permalink) Old 06-10-2019, 07:56 PM
Herb is pointing out something that is true of most collets. Loosen til it tightens, then loosen some more until it releases the bit. The tolerances involved in a collet are a few thousandths of an inch. Metric bits in Imperial collets are possibly a problem but living and buying in the U.S. it's unlikely.
JFPNCM likes this.
post #4 of 18 (permalink) Old 06-10-2019, 08:50 PM
I have some metric bits and you can tell when you try them in an imperial size collet. At least for 6mm and 12mm. Way too loose in the collet. I doubt they would tighten enough to hold. The poster might also be over tightening the collet.
post #5 of 18 (permalink) Old 06-10-2019, 08:55 PM
Maybe the collet is metric and not imperial?
post #6 of 18 (permalink) Old 06-10-2019, 11:20 PM
kp91's Avatar
First Name: Doug
You are probably bottoming out the bits in the collet. This creates a bur or deformation on the shank making them hard to get out
JFPNCM and Herb Stoops like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 18 (permalink) Old 06-11-2019, 07:58 AM
First Name: Art
Clean the collet it could possibly have a bit of rust in it.
mgmine is offline
post #8 of 18 (permalink) Old 06-11-2019, 08:12 AM
Turn it till it unlocks,,,
post #9 of 18 (permalink) Old 06-11-2019, 03:43 PM
MEBCWD's Avatar
If the collet nut was tightened without a bit installed it might have compressed the collet and made it tight for bit insertion. That is one problem with this collect design.
MEBCWD is online now
post #10 of 18 (permalink) Old 06-11-2019, 06:29 PM Thread Starter
JimofSC's Avatar
Thanks all for the feedback. I learned about collets.
So this is up-date:
My Ryobi uses a Taper shaft with multi-slits.
I use Whiteside Bits with ¼” shaft, all are US size
I have checked the shafts and they have no burs
So maybe I have over tightened the collet nut? This may be the case as the first time I used a router (many years ago) the bit came out, fortuity no damage to me or the piece. But since then I have been cautious about tightening. Maybe the first time I used this router I over tightened??
JimofSC is offline
