Edge flush routing - Router Forums
 6Likes
post #1 of 14 (permalink) Old 06-16-2019, 03:22 PM Thread Starter
Default Edge flush routing
Trying to find the jig my friend has for routing 3/4" hardwood flush with the table top surface.
The big is metal with a phenolic base. The porter cable router is offset and there is a round knob to hold the plate flat on the table surface. There is a bearing guide that rolls along the edge of the table as a guide. The router is adjusted so it cuts the wood edging flush with the top.
Anyone know the manufacturer of the jig and where I can find one?
Blockwood2019 is offline
post #2 of 14 (permalink) Old 06-16-2019, 03:52 PM
I made one that worked okay. It was pretty simple to make. https://www.routerforums.com/jigs-fi...ing-flush.html
roxanne562001 likes this.
post #3 of 14 (permalink) Old 06-16-2019, 04:21 PM
Will these help???
post #4 of 14 (permalink) Old 06-16-2019, 08:57 PM
First Name: Orlando
It may help if you could post a picture of what your friend has. That way we'll know what it looks like and would be able to give you more precise information. The only thing I can even guess what you are describing is Pat Warner's Right Angle Template that was phenolic with an aluminum fence and his offset subbase.
OBG65 is offline
post #5 of 14 (permalink) Old 06-16-2019, 09:21 PM
ger21's Avatar
First Name: Gerry
ger21 is offline
post #6 of 14 (permalink) Old 06-16-2019, 10:34 PM
Wow, $679. Mine was free. I could have added strips at the edge to keep it running along the edge and it would still do the same thing for free.
post #7 of 14 (permalink) Old 06-17-2019, 06:41 AM
sreilly's Avatar
First Name: Steve
I think that's white gold. $180-200 for the router and $480 for the jig? Now that Chic! Can't use this as it won't store well in my safe. Where do people get these prices? Ok , I know more coffee.............or meds
Cherryville Chuck likes this.
sreilly is offline
post #8 of 14 (permalink) Old 06-17-2019, 01:11 PM
Contributor of the Month
I've never seen the commercial one but I founds plans for a DIY one. If you're interested and it's legal to do I can upload the plans.
JIMMIEM is offline
post #9 of 14 (permalink) Old 06-17-2019, 05:51 PM
First Name: Orlando
Ok. now I know what he's talking about. But at $679!!!
OBG65 is offline
post #10 of 14 (permalink) Old 06-20-2019, 02:45 PM
CharleyL's Avatar
First Name: Charley
if you want to buy the jig, I like to use my CRB7 router jig. It will flush trim, has an offset knob handle, and it can do many other things as well, if you buy it with the options it will do more than the 7 functions of it's original design. Like centered Mortising, laminate trimming, small circle cutting, very large circle cutting, etc.
For making just a router base with an elongated shape and a handle off to the side, I made my own by tracing the original router base outlines onto a piece of 3/8" clear Lexan (Lexan won't shatter or crack) and then took a small can and drew around it to make the curve on the elongated area. Then I just drew in the straight lines between the circles, cut it out on my band saw, and smoothed the edges on my belt sander. I then drilled holes to match the original router base and one hole in the small rounded area to attach a handle. You can use any kind of handle that you like. I chose a large cylindrical handle from the gray drawers at Lowes for my offset handle.
Charley
Central North Carolina
CharleyL is offline
