What's the right tool for the job. - Router Forums
 14Likes
post #1 of 18 (permalink) Old 07-05-2019, 06:30 PM Thread Starter
Default What's the right tool for the job.
I've been making adirondack chairs with the shape of Minnesota as the back rest. I'm currently using a scroll saw the cut the shape out. The backs are made using 4 1x6 boards. My question is what would be the most efficient tool to use, scroll saw, or a router with a pattern bit. If router bit what style and brands would you recommend.
Douglas Uzzle is offline
post #2 of 18 (permalink) Old 07-05-2019, 06:42 PM
If it's a cutout, scroll saw gets my vote. However, if it is not, then a router seems the better answer. With four pieces it might be a problem cutting out the shape and still having the back support a person properly.
post #3 of 18 (permalink) Old 07-05-2019, 07:07 PM
welcome to the forums N/A
stay w/ the jigsaw..
use the correct blade for the mission...
using the router you'll still need to hog out the design...
however a pattern and a router will give you a cleaner finish..
for the bit...
https://www.freudtools.com/products/42-204
pal, roxanne562001 and jj777746 like this.
Stick486 is offline
post #4 of 18 (permalink) Old 07-05-2019, 10:01 PM
ger21's Avatar
First Name: Gerry
Bandsaw would be fastest.
Cherryville Chuck likes this.
Ger
www.cncwoodworker.com
ger21 is offline
post #5 of 18 (permalink) Old 07-06-2019, 12:37 AM
G'day Douglas, welcome to the forum.
Sydney, Australia
jw2170 is offline
post #6 of 18 (permalink) Old 07-06-2019, 01:40 AM
Welcome to the forum Douglas. One of the reasons members are encouraged to fill out their profiles is so that we know what tools you have to work with. I agree with Gerry that a bandsaw is by far the fastest machine to get rid of the bulk of the material. But that isn't helpful if you don't have one. Next would be a jigsaw, if you have one. Routers aren't good at removing large amounts of wood and bits wear more quickly than other cutting tools and are more costly than other methods. However a pattern or flush trim bit is ideal for producing a finished edge (maybe with a little sanding) when following a pattern of the finished profile. So a multi machine approach is probably the best where you use a bandsaw or jigsaw to cut the basic pattern out, leaving 1/16th to 1/8th inch of wood to rout . That will give you a finished product with the least amount of time spent sawing and sanding.
roxanne562001 likes this.
post #7 of 18 (permalink) Old 07-06-2019, 08:58 AM
ger21's Avatar
First Name: Gerry
One thing to consider when using a router to trim or cut the ends of boards like you're proposing is that tearout can be a serious issue. You'll probably want to use a backer board.
If you're making a lot of these, I'd make a dedicated template/jig for each board that incorporates a backer board. I'd rough cut themon a bandsaw, or with a jigsaw, and then clean up the ends with the router.
Danman1957 and jj777746 like this.
Ger
ger21 is offline
post #8 of 18 (permalink) Old 07-06-2019, 09:09 AM
sreilly's Avatar
First Name: Steve
Welcome to the forum Douglas. Pictures might help fully explain what you're doing now and what improvements could be made.
sreilly is offline
post #9 of 18 (permalink) Old 07-06-2019, 09:48 AM
Originally Posted by ger21 View Post
bandsaw would be fastest.
maybe not...
pal and roxanne562001 like this.
Stick486 is offline
post #10 of 18 (permalink) Old 07-06-2019, 10:04 AM
roxanne562001's Avatar
First Name: Roxanne
Welcome to the forum Douglas. I am with the group on this. I would say the scroll saw that would take the least amount of material. I cut allot of toys out on the scroll saw using 3/4" material. it goes pretty quick and not much waste. I used to make quite a few rocking horses. out of 1 1/2" stock. I would rough the parts in on the band saw then clean up them up with a router and a flush trim bit following a mdf pattern that I attached with double sided tape. https://www.amazon.com/Freud-Bearing.../dp/B0000225YCSend some pics we would love to see it.
roxanne562001 is offline
