Bosch 1617 collett - Router Forums
post #1 of 9 (permalink) Old 07-18-2019, 07:33 AM Thread Starter
Default Bosch 1617 collett
Anyone having problems wit Bosch 1617 collett ?
Sawdust74 is offline
post #2 of 9 (permalink) Old 07-18-2019, 07:46 AM
Semipro's Avatar
First Name: John_*
What is your problem with the collet?
Semipro is offline
post #3 of 9 (permalink) Old 07-18-2019, 08:20 AM
no..
post #4 of 9 (permalink) Old 07-18-2019, 10:19 AM Thread Starter
Collet seems to loosen, however the bit will not release, have to use the wrench to loosen again then try to remove the bit.
post #5 of 9 (permalink) Old 07-18-2019, 11:00 AM
It`s supposed to loosen a couple of turns and then get tight again so that you have to use the wrench. When you loosen the second time it`s supposed to push the collet out of the forcing cone in the arbor.
post #6 of 9 (permalink) Old 07-18-2019, 11:33 AM
MikeMa's Avatar
That is correct, it is working as designed. This is a safety feature to make sure the bit doesn't get loose while the router is running.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #7 of 9 (permalink) Old 07-19-2019, 09:09 AM
TenGees's Avatar
First Name: Paul
From the manual:
REMOVING THE ROUTER BIT
1. Use the shaft and collet chuck wrenches as described earlier, and turn the collet chuck assembly in a counter-clockwise direction.
2. Once the collet chuck assembly is loosened continue to turn the collet chuck assembly until it pulls the collet free from its taper, and the router bit can be removed.
NOTE: The collet chuck is self-extracting; it is NOT necessary to strike the collet chuck to free the router bit.
You're not the only one with this issue. Many people have asked the same question.
TenGees is offline
post #8 of 9 (permalink) Old 07-19-2019, 10:57 AM
JFPNCM's Avatar
First Name: Jon
Agree with the points made above.
Jon
JFPNCM is offline
post #9 of 9 (permalink) Old 07-19-2019, 11:36 AM
Yup, it's normal. Works as designed. I keep a spare half inch collet on hand because they are really a precision device and it's a matter of a few thousandths between one that's good and one that's bad.
