round in circles - Router Forums
 33Likes
post #1 of 28 (permalink) Old 07-20-2019, 12:32 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default round in circles
I cant work out which way to cut a circle, or even if it matters.
I'm using a plunge router on a trammel, going to cut a circle in a square piece of beech. using a straight sided plunge router bit, should i go clockwise, or anticlockwise?
sunnybob is offline
post #2 of 28 (permalink) Old 07-20-2019, 05:56 PM
vchiarelli's Avatar
First Name: Vince
counterclockwise - same as you would do for an outside edge.
vchiarelli is offline
post #3 of 28 (permalink) Old 07-20-2019, 05:59 PM
pal, roxanne562001, HoweA and 1 others like this.
Stick486 is offline
post #4 of 28 (permalink) Old 07-20-2019, 08:30 PM
According to Pat Warner, it doesn't matter. I'e attached a copy of the instructions that came with his circle jig and he suggests cutting halfway in one direction and then reversing to complete the circle, more so that the vacuum hose and cord don't get tangled up. It always amazes me that people don't make the plate on circle jigs with a hole for a guide bushing rather than bolting the router to it - with the router pivoting on the guide bushing, the router can stay in the same relative position while making the cut and there's no problem with the cord tangling. One of these days, I'm going to look at making a bushing for his base plate - OD to fit the existing hole and ID for a guide bushing, probably 3/4". I do see that Festool makes their version to use the guide bushing, and there used to be a US manufacturer that did that too, and I thought that I had one but haven't seen that for a while.
tomp913 is offline
post #5 of 28 (permalink) Old 07-20-2019, 08:46 PM
one direction will give ya fuzzy edge to the outside...
the other to the inside...
pick yur poison...
pal, JFPNCM, Herb Stoops and 1 others like this.
Stick486 is offline
post #6 of 28 (permalink) Old 07-20-2019, 11:17 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
See? I knew it was confusing. I'm not trimming an edge (then I would know which way to go). I'm plunging into the wood, so if I go clockwise, one edge is cutting, but if I go counter clockwise, the other edge is cutting (I think).
Herb Stoops likes this.
sunnybob is offline
post #7 of 28 (permalink) Old 07-21-2019, 12:00 AM
JFPNCM's Avatar
First Name: Jon
I start by drilling a bit sized hole all the way through the material and then lower the bit there by small increments. Always have run counterclockwise
The sound of the bit changes when you come back to the hole and i stop there, raise the bit and power down. This allows me to clean any residual dust and chips from the piece before lowering the Bit slightly and cutting another pass.
I also rest the center piece on small padded blocks (prevents slippage) which allows me to cut through the piece on the last pass. However, if I need a good edge on the bottom side, I skip the blocks, use double sided tape to prevent slippage and cut through into a resting blank under the piece.
I use a spiral upcutting bit as well.
pal, Herb Stoops and jj777746 like this.
Jon
JFPNCM is offline
post #8 of 28 (permalink) Old 07-21-2019, 12:53 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I like the pilot hole idea.
On this circle I have drilled the centre hole all the way through so can just turn the block over to get a clean cut on the underside.
I dont have any spiral bits, just cheap straight ones that I am going to use up before spending money on better ones.
JFPNCM, TenGees and Herb Stoops like this.
sunnybob is offline
post #9 of 28 (permalink) Old 07-21-2019, 03:42 AM
JOAT's Avatar
First Name: Theo
Well, how big is the hole to be? If small enough, I would just use a hole saw, my largest is 7". Hmm, just remembered, I've also got an adjustable hole cutter thingie, works great for pretty large holes, but takes forever.
JOAT is offline
post #10 of 28 (permalink) Old 07-21-2019, 04:39 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I've cut it, but learnt a lot on the way. mainly to not do what I did this time.
The finished disc is 13" across.
If I did this again I would mark out the circle, cut close to it on the bandsaw, then use the router table to finish the cut.
The router and bit I used was not man enough for 1" thick beech, even turning it over and cutting from the bottom as well.
Oh well, "if I can learn something, my day has not been in vain"
sunnybob is offline
