1/4 bits all undersized by .001 - Router Forums
 32Likes
post #1 of 37 (permalink) Old 08-01-2019, 09:30 PM Thread Starter
Default 1/4 bits all undersized by .001
Is this normal? All my 1/4 bits are approx .249 rather than the full .250"
martik777 is offline
post #2 of 37 (permalink) Old 08-01-2019, 09:49 PM
shank or cutter??
post #3 of 37 (permalink) Old 08-01-2019, 09:51 PM Thread Starter
Shank
post #4 of 37 (permalink) Old 08-01-2019, 09:59 PM
difalkner's Avatar
First Name: David
My 1/4" compression bit measures 0.245" (cutter), the shank measures 0.249".
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #5 of 37 (permalink) Old 08-01-2019, 10:22 PM
normal...
harrysin and jw2170 like this.
post #6 of 37 (permalink) Old 08-01-2019, 10:28 PM
So? That is a pretty close tolerance. Is it loose in the collet? I can't imagine that it's significant.
post #7 of 37 (permalink) Old 08-01-2019, 10:56 PM Thread Starter
No, I made a collet for someone and they mentioned they could not easily get a .250 shank to fit. I machined it to slip fit a .249" shanked bit.
Checked all my bits and not one is .250. They are all between .249 and .2493
post #8 of 37 (permalink) Old 08-02-2019, 01:46 AM
Well if the hole (collett) is .250 than the shank has to be smaller (.249) otherwise it ain't gonna fit.
pal and DesertRatTom like this.
DaninVan is offline
post #9 of 37 (permalink) Old 08-02-2019, 09:39 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I just checked these three bits picked at random and the accurate one happens to be one of two that I bought off E Bay some years ago and they cut just fine. 1/4" = 6.35mm
Harry
harrysin is offline
post #10 of 37 (permalink) Old 08-02-2019, 12:12 PM
TenGees's Avatar
First Name: Paul
Making a 'roller' for a roller stand the other day. I noticed the same issue, drilling a 1/4" hole and expecting it to turn on a 1/4" bolt. I could barely get the bolt in (without using a hammer). So I measured some bits to see if I could find an oversized one... all of them were undersize! I finally found a knurled punch that opened the hole a bit. I guess the knurling added a little width to 1/4" material it was made from???
DaninVan likes this.
TenGees is offline
