ER20 Extentsion chuck - Router Forums
 9Likes
  • 2 Post By ger21
  • 1 Post By RainMan 2.0
  • 1 Post By ger21
  • 2 Post By MEBCWD
  • 2 Post By ger21
post #1 of 8 (permalink) Old 08-10-2019, 09:45 AM Thread Starter
Default ER20 Extentsion chuck
I've been looking into the ER20 Extension chuck can be found here on Amazon https://www.amazon.co.uk/gp/product/...XSIFIWIA&psc=1
If I bought this I could use endmills in my router.
So I was just wondering if there would be any Cons in upgrading my chuck
TomTomthumb is offline
post #2 of 8 (permalink) Old 08-10-2019, 09:53 AM
ger21's Avatar
First Name: Gerry
Any runout in the collet will be magnified the further the chuck sticks out, which may cause some vibration, depending on how accurate your collet is. Other than that, no issues.
neville9999 and MEBCWD like this.
Ger
www.cncwoodworker.com
ger21 is offline
post #3 of 8 (permalink) Old 08-10-2019, 12:08 PM
RainMan 2.0's Avatar
Would a muscle chuck give you appropriate length ? You’d also have a quick change system at the same time
https://www.rockler.com/quick-change...de-musclechuck
Gaffboat likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 8 (permalink) Old 08-10-2019, 12:23 PM
This looks like the American Equivalent :
https://www.amazon.com/Wolfride-Rout...ateway&sr=8-11
A tad cheaper than the Musclenut.
Herb Stoops is online now
post #5 of 8 (permalink) Old 08-10-2019, 12:38 PM
That was my concern also . Big price difference, but it gives you the easy change option
Herb Stoops likes this.
post #6 of 8 (permalink) Old 08-10-2019, 05:15 PM
ger21's Avatar
First Name: Gerry
The ER collet gives you unlimited choice of shank sizes. Which I think is what the OP was looking for.
MEBCWD likes this.
Ger
ger21 is offline
post #7 of 8 (permalink) Old 08-11-2019, 09:04 AM
MEBCWD's Avatar
I would caution against using the 1/4" shank version. That is a lot of weight added and any runout would be a lot of sideways force against that 1/4" shaft. Add to that the weight of the bit and it's added extension form the collet.
radios and RainMan 2.0 like this.
MEBCWD is offline
post #8 of 8 (permalink) Old 08-11-2019, 10:21 AM
ger21's Avatar
First Name: Gerry
Yes, definitely do not try one with a 1/4" shank. I didn't even know they made those.
radios and MEBCWD like this.
Ger
ger21 is offline
