Ryobi CR1000VA bearing replacement - Router Forums
 1Likes
  • 1 Post By derekt
post #1 of 5 (permalink) Old 09-06-2019, 02:31 AM Thread Starter
Country: New Zealand
First Name: Derek
Default Ryobi CR1000VA bearing replacement
Hi Everyone,
Wondered if someone can tell me how to separate the plastic top portion from the aluminium lower portion so that I can replace both top and bottom bearing in my router.
I assume there must be screws that need undoing to release the two parts. So far I haven't found them and wondered if they are the two hex headed screws shown in one of the parts diagrams on the net which seem to be under the electric connection block and labeled as part 37.
Have attached a picture
Any suggestions much appreciated.
derekt is offline
post #2 of 5 (permalink) Old 09-06-2019, 08:37 AM
sreilly's Avatar
First Name: Steve
Welcome to the forum Derekt. A quick search brings up this possibility for parts and an exploded diagram which often helps in seeing how it was assembled. The diagram is attached as well. Looks similar but maybe larger. Otherwise maybe someone on the forum has one or similar that can assist.
sreilly is online now
post #3 of 5 (permalink) Old 09-06-2019, 12:17 PM
Most of the routers I've had apart had a top cap that was held on by screws which you removed and then you had to remove the field coils and armature to get at the lower bearing. A quick look at the diagram Steve provided makes it look like that might be the case with yours too Derek.
post #4 of 5 (permalink) Old 09-06-2019, 04:24 PM Thread Starter
First Name: Derek
Thanks Steve and Charles
Yes the diagram does mention a couple of hex head screws which maybe what I am looking for. Bacon and eggs for breakfast then down to the workshop to see if I can find them. They maybe under the incoming power cable holding clamp and I just haven't found them yet.
Thanks for your comments
Derek
derekt is offline
post #5 of 5 (permalink) Old 09-09-2019, 11:26 PM Thread Starter
First Name: Derek
Red face Ryobi Router
Hi Gentlemen,
You were correct the two hex headed screws/bolts were under the speed control electronics on one side and the switch gear on the other.
All apart now, bearing procured and just have to put it back together.
Appreciate your respective help and hopefully it will be up and going again later today.
Regards
Derek
Cherryville Chuck likes this.
derekt is offline
