New Member, Looking for input on project (Garden Arch) - Page 3 - Router Forums
 17Likes
post #21 of 74 (permalink) Old 09-19-2019, 12:55 PM
First Name: mary
Welcome to the forum, I am sure there are people here that will be able to help you.
marecat3 is offline
post #22 of 74 (permalink) Old 09-19-2019, 12:59 PM
Originally Posted by ABear View Post
Thank you for the ideas. I don't have a band saw. I am cutting the pieces with a miter saw and a fine finish blade so I am getting smooth cuts/joints. I do plan on glue (Titebond) and screws and overlapping. The arch is based on modifications of one I saw in Popular Mechanics.
consider:
at least the birdsmouth joint to help shed water...
Weldbond glue instead of TB... BUT, I wouldn't glue, the wood has/needs to move.. a strong joint will encourage splitting someplace else...
don't do butt joints, do lap joints... way better water shedding - think like a shingle..
slot screw your boards onto the arch rafters ... this will allow for seasonal wood movement... or use clips... think table top to apron mounting...
support the ''roof'' w/ rafters...
instead of 6/4 material use 4/4 for the ''roof''...
pocket screws will fail because of their inability to move w/ the wood's swelling and shrinking equaling open butt joints which become progressive issues...
File Type: pdf Weldbond Specifications & Instructions.pdf (82.1 KB, 14 views)
Nickp likes this.
post #23 of 74 (permalink) Old 09-19-2019, 02:12 PM
Originally Posted by MEBCWD View Post
Here is the link to the calculator.
Woodturners Resource Segment Calculator
thanks...
post #24 of 74 (permalink) Old 09-20-2019, 10:17 AM Thread Starter
First Name: Robert
@Stick486
Thanks again for all the comments. I do have a couple more questions and wanted to add a few details on the project.
I am using pressure treated lumber for the post, I let them dry out over the Summer, they are 4" X 4" oversize so they are 4-1/8" X 4-1/8" actual. They are already set in concrete about 28" deep and measured square corner to corner, 28" is way below my local frost line. Inside width about 44", outside adds 8-1/4" so about 52 1/8" outside. Overall depth about 34"
I have picked up a couple WRC 1 X 6 X 8 boards to go on top of the post, my plan was to use both boards (so 1.5" thickness total) on top of the post and then attach the actual arch to the top boards.
Here are my questions;
You mentioned using 4/4 vs. 6/4 for the top, since I am targeting a 3" thick on each arch piece (double 2 x 6 thick) that is extra cost extra lumber, will you please elaborate on the advantages of why you suggest this approach.
Slot screwing the connecting pieces on the arch is a great idea, thank you.
I can see how weak a butt joint would be, I can see the advantage of using splines. I am debating the Freud Slot Cutter vs. just using my table saw with a jig, I am undecided but here is my next question.
My plan was to off set the 2 x 6's on top of each other as in the attached picture, this should add a lot of strength, would you still recommend the splines. I am guessing yes and if so I will add splines.
OK, here is where I am lost, you recommend a birdsmouth joint. I looked it up and understand the joint and its use. I assume you are recommending this for attaching the arch bottom to the frame, if other than that, I need you to provide me some more details.
Thank you once again.
ABear is offline
post #25 of 74 (permalink) Old 09-20-2019, 02:39 PM
@Stick486
1... I am using pressure treated lumber for the post. They are already set in concrete
2... I have picked up a couple WRC 1 X 6 X 8 boards to go on top of the post, my plan was to use both boards (so 1.5" thickness total) on top of the post and then attach the actual arch to the top boards.
3... You mentioned using 4/4 vs. 6/4 for the top, since I am targeting a 3" thick on each arch piece (double 2 x 6 thick) that is extra cost extra lumber, will you please elaborate on the advantages of why you suggest this approach.
4... I can see how weak a butt joint would be, I can see the advantage of using splines. I am debating the Freud Slot Cutter vs. just using my table saw with a jig, I am undecided but here is my next question.
NOTE:
any glue up on WRC needs to be treated as an oily wood...
Weldbond can be had from ACE hardware....
6... My plan was to off set the 2 x 6's on top of each other as in the attached picture, this should add a lot of strength, would you still recommend the splines. I am guessing yes and if so I will add splines.
5.. .OK, here is where I am lost, you recommend a birdsmouth joint. I looked it up and understand the joint and its use. I assume you are recommending this for attaching the arch bottom to the frame, if other than that, I need you to provide me some more details.
1... FWIW, I would have used WRC posts and the next time you set a post, set it in pea gravel. CC in contact w/ wood promotes rot because it keeps the wood wet... wood+water=rot....
2... could you clarify...
3... a 2by is actually 6/4 thick.. 4/4 is a 1'' thick... a 1x is 3/4'' thick...
clapboard your roof like shingles to promote water run off... kant (if need be) the face of the top edge of the board that is under the next board going up hill for a better fit... (run the board through your TS on it's edge to get the angle you need)... cut flats to fit on top of your arch to fit the clapboards... a butted joint is going to open, which leads to failure, no matter what you do... on second thought, a 2x may give you more wiggle room and better/cleaner esthetics...
4... the TS is your best bet.. no jig required... stand your board on it's edge to cut the slot...
5... you are building a barrel vault... splines for butt joints, but butt joints, for me, on the roof boards would be pretty far down the method list... DO spline your arch segment's butt joints...
6... the birdsmouth is an alternate butt joint for your roof boards... study the picture I posted, the lip is on the down slope and acts as a water shed...
can you post a link to your plan???
post #26 of 74 (permalink) Old 09-20-2019, 07:55 PM Thread Starter
First Name: Robert
Thank you Stick, the Router Forums will not allow me to hotlink a URL as a new Member, I am sure it is to keep the spam down. I have a screen grab of the website that shows the plan, my plan is just a modification of this plan to make it larger and the cross ties on the top I plan on using 2 x 2 WRC stock, also 2 x 2 WRC stock on the side laths. I have attached a picture which shows a couple boards between the upright posts and the arbor. These are the boards mentioned in the #2 item that you asked for clarification.
I am going to review your latest comments and see if I have questions, thank you again for taking time to help!
ABear is offline
post #27 of 74 (permalink) Old 09-20-2019, 08:33 PM
hurry and get your 10 posts
post #28 of 74 (permalink) Old 09-20-2019, 09:13 PM Thread Starter
First Name: Robert
Well, this should put me over the limit, post 10.
ABear is offline
post #29 of 74 (permalink) Old 09-20-2019, 09:15 PM Thread Starter
First Name: Robert
ABear is offline
post #30 of 74 (permalink) Old 09-20-2019, 09:16 PM Thread Starter
First Name: Robert
ABear is offline
