New Member, Looking for input on project (Garden Arch) - Router Forums
 23Likes
post #1 of 86 (permalink) Old 09-18-2019, 08:01 PM Thread Starter
First Name: Robert
Default New Member, Looking for input on project (Garden Arch)
Hello to all and thank you for letting me join the Router Forums community.
I am in the process of making the wife an arbor for the backyard garden and have some questions, mostly looking for expert advice. The arbor is basically made using Qty four 4 X 4 post in a square pattern and the top arch is the part in question. The arch top will be made with Cedar 2 x 6's, and will be 3" thick (doubling up the 2 x 6's), I used a segment calculator, determined the length of each segment at roughly 21.5" and cut the 2 x 6's at 22.5 degrees (basically a half octagon). Arch will be big, basically 51" or so outside, to 44" inside (give or take a little).
My Router is a Craftsman 27683 12 amp 2HP (Chervon Mfg, thinking maybe a Chinese copy of a Bosch 1617).
I do have a router jig, Jasper Model 300. I know I could have made a jig. I am trying to simplify and take potential pitfalls out of the equation.
The router bit is a Whiteside #RU5150 Spiral Up Cut Bit - 1/2" SH X 1/2" CD X 1-1/2" CL
I literally have zero router experience even though I have a fair amount of woodworking experience, four years High School wood-shop using Shapers, Planers, Jointers, Cabinet Saws, Lathes, etc.
I have cut the 2 x 6's to keep the grain all oriented the same direction the best I can.
I plan on taking shallow passes, even though I have not determined what constitutes a shallow pass, maybe 1/8"?
Plan on keeping the feed rate slow, RPM's at ???? (Router has 10,000 - 25,000 as I recall).
Plan on clamping the work down to a solid table, working at about normal workbench height.
I have mocked up a doug fir 2 x 6 top to get some practice, beyond that I have no idea what I am doing.
My comments above are based on my research of do's and don'ts.
THANK YOU FOR ANY COMMENTS!
Bob Adams and 1fizgig like this.
ABear is offline
post #2 of 86 (permalink) Old 09-18-2019, 09:10 PM
welcome to the the forums Robert...
''I literally have zero router experience''...
we can help w/ that...
head over to this link for some light reading... (splines are covered there)
for other than the splines, I believe a router isn't the best tool for this project...
your cedar, is it Western Red Cedar??? It should be...
If I interpret what you doing you are actually making a vaulted arbor w/ a solid ceiling/roof... Correct???
your wood is going to have seasonal movement like it was trying to move it's self next door unless you select it carefully..
your staves..
I would use a splined (if the arch is self supporting) birdsmouth joint easily done on the table saw w/ a dado blade...
cut the spline groves w/ a slot cutter...
use white oak for the splines...
got more questions??? ask away!!!!
post #3 of 86 (permalink) Old 09-18-2019, 09:11 PM
@ABear ...
do you have a link to that calculator???
post #4 of 86 (permalink) Old 09-18-2019, 09:19 PM
If you have mocked up the arch using fir and have cut it, you now have a template you can use. Or draw one segment on a piece of hardboard and cut it out.
Myself, I would first cut each 2 x 6 segment into its arc shape with a band saw. Cut one in half and assemble them with an overlap joint, gluing and/or screwing them. Then finish with a belt sander.
FixitMike is online now
post #5 of 86 (permalink) Old 09-18-2019, 09:25 PM
Bob Adams's Avatar
First Name: Bob
Robert welcome to the forum! That is a cool project. I have a couple of questions. How are you joining your segments? End to end grain glue ups are not very strong. I would probably dowel or loose tenon the joints. Are you going to glue up one full octagon, rout and then cut in half, or do 1/2 at a time? (this is just curiosity) Either way I would make a template and draw out the outer and inner circles, use a jig saw to cut close to the lines, within in a 1/16" then rout with your circle jig. Then with cedar or doug fir I would be comfortable with my depth of cut being 3/4". But shallower passes wouldn't be a bad thing either.
Bob Adams is online now
post #6 of 86 (permalink) Old 09-18-2019, 10:49 PM
old55's Avatar
First Name: Ross
Welcome to the forum Robert.
Ross,
old55 is offline
post #7 of 86 (permalink) Old 09-19-2019, 12:45 AM
Welcoms to the Forum and that's a really nice project. You have 8 segments for the full circle, four for an arch. Cut the angles first, lay out the half circle, and I'd use a pencil through a stick, with a sharp point on the other end to draw the arch. I'm with Stick on using oak splines to join them, otherwise you could use lap joints, but that will be trickier to measure and cut. Splines with weather resistant glue are very strong.
When cutting the splines on the ends, make sure you put the face toward the fence on every piece so your grooves are aligned. I'd cut fairly deep and use splines that were 3-4 inches long
Personally, I'd use 2x6 red cedar if I could find it so the arch would be a little wider. Where the ends joined the vertical sides of the opening, I'd go with a bit wider wood. But I live in the desert and the weather extremes will be hard on whatever I used, so I tend to overbuild a little.
I would make the curved cuts on a band saw, or a good jig saw. I'd roundover the edges of the curved pieces a little. Not sure this is much of a router project unless you used a pattern. But even then I'd make the curved cut with a band or jig saw, and use the router to clean it up. Cut just outside the line 1/16th with the band or jig saw and clean it up later.
One other option for setting up the curve would be to buy some half inch MDF. Cut it to the width of the arch, then using a trammel (stick with pencil on the end, a nail on the other. The inside and outside radius will be the nail insertion point. Draw the arc. You could do this on a small sheet of mdf, or even directly on your precut 2x. Place a same thickness piece for the nail to ride on.
Just thinking this out a little. The simpler the method, the more likely it is to turn out well.
post #8 of 86 (permalink) Old 09-19-2019, 10:08 AM
Contributor of the Month
Bushwhacker's Avatar
First Name: David
I just recently made one of these for the front yard. Mine is not quite like the one in the drawings but it worked for us. It can be seen and how I did it on my UTUBE ( (Entry Arch) David Peterson, Take a look if you would like. I also made one like the one you have in the picture many years ago. AS shown, I cut out the curved pieces and off set them to double them up. To my knowledge, it is still standing, and that was over 25 years ago.
David
Note
AS Stick said, watch the grains of the cuts or it will crawl all over the place.
When the enemy is in range, so are you.
Bushwhacker is offline
post #9 of 86 (permalink) Old 09-19-2019, 10:26 AM Thread Starter
First Name: Robert
your staves..
Thank you Stick, lots of good reading at the link you provided!
I was not familiar with splines, looks like biscuits without the biscuit/biscuit cutter. Thank You!
Yes, the arbor picture you uploaded is pretty much exactly what I am building.
Yes, Western Red Cedar. I live in the PNW so WRC is plentiful and affordable.
ABear is offline
post #10 of 86 (permalink) Old 09-19-2019, 10:29 AM Thread Starter
First Name: Robert
@ABear ...
The forums will not allow me to post a URL as a new member so I have a screen grab of the website. I found several others if you are interested.
ABear is offline
