Found my problem the hard way - Router Forums
 16Likes
post #1 of 11 (permalink) Old 10-02-2019, 11:31 PM Thread Starter
Default Found my problem the hard way
I keep a big ole Triton in a table with a roundover bit just for knocking off the sharp corners on my signs and plaques. Started to notice it was taking off more material than usual so I checked to make sure it was still solid in the plate, which it was, and everything else seemed ok. I readjusted the height and tried it out. Seemed ok at first but then it gouged the sign I was routing, made an awful racket, and the bit popped out and fell to the floor along side of the table. The collet was just loose enough to move under pressure but not noticeable when I checked it. Wasn't close to causing any damage to me or anything else, but it ruined the sign. I put the bit back in, tightened it down, and all seems well again. The firepit has more fuel.
artman60 likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #2 of 11 (permalink) Old 10-02-2019, 11:47 PM
RainMan 2.0's Avatar
Well I’m thinking you may have got off easy . I could hardly imagine a bit spinning at 10,000 rpm coming out of the router .
Glad the damage was minimal and you weren’t hurt . I’ll have to remember this event for my own safety. Thanks for sharing John.
It’s scary how things can go south so quickly
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 11 (permalink) Old 10-03-2019, 12:45 AM
JOAT's Avatar
First Name: Theo
Originally Posted by RainMan 2.0 View Post
Well Iím thinking you may have got off easy . I could hardly imagine a bit spinning at 10,000 rpm coming out of the router .
Glad the damage was minimal and you werenít hurt . Iíll have to remember this event for my own safety. Thanks for sharing John.
Itís scary how things can go south so quickly
Way I see it, you should always be a little afraid of any of your tools. That way you are always careful. Not afraid means over-confident, and don't pay as close attendion as you should, and that's how you get hurt.
Barry747, artman60 and 1fizgig like this.
JOAT is online now
post #4 of 11 (permalink) Old 10-03-2019, 08:56 AM
sreilly's Avatar
First Name: Steve
John I'm a bit surprised that you keep a bit installed. The safe thing would be to double check the collet tightness each time you sue the router just in case as you found out. I realize that keeping it installed is faster because the height is already set and likely the fence is where it needs to be but.....the extra time to check is well worth it I'm sure. Of course I'm not guilty of this but likely would be if I were doing what you do so you did indeed have a teachable moment that turned out well. Bad case would have been a broken /chipped bit, worse case an injury and broken bit. Neither is good.
Thanks for sharing that teachable moment to remind us all. Seriously, we often don't think of such things till we hear about someone else's accident/mistake.
sreilly is offline
post #5 of 11 (permalink) Old 10-03-2019, 09:00 AM
TenGees's Avatar
First Name: Paul
I leave bits in a couple of routers and double checking the chuck tightness is not something that I'm in the habit of doing... I guess that I better change my habits!
Glad that you didn't get hurt, John.
TenGees is offline
post #6 of 11 (permalink) Old 10-03-2019, 09:12 AM
David Bradford's Avatar
First Name: David
I usually keep 5 or 6 routers set up permanently and have a few that get set up for what is needed. I had maybe a bit or 2 come loose but generally had more bearings come apart and ruin a piece of work.
Herb Stoops likes this.
David drafter @ Linear Fine Woodworking in Phoenix
[email protected]
http://www.linearfinewoodworking.com
David Bradford is offline
post #7 of 11 (permalink) Old 10-03-2019, 12:16 PM
JFPNCM's Avatar
First Name: Jon
Indeed a teachable moment. Pleased to see you escaped unharmed.
Jon
JFPNCM is online now
post #8 of 11 (permalink) Old 10-03-2019, 02:00 PM
JOAT's Avatar
First Name: Theo
I keep my bit in permanently also. And also the only issue was bearings coming apart. May have solved the bearing problem tho, ever since I started putting a drop or two of oil on the bearing before using, I have had no bearing failures.
artman60 and David Bradford like this.
JOAT is online now
post #9 of 11 (permalink) Old 10-06-2019, 07:33 PM
artman60's Avatar
First Name: Artie
Sorry one of your works of art made it into the fire. I did learn something tho.
honesttjohn likes this.
The clock of life is wound but once.
artman60 is offline
post #10 of 11 (permalink) Old 10-07-2019, 12:21 AM
gdonham1's Avatar
First Name: Guy
It is tempting to leave something setup permanently and just walk up and turn it on use, abuse it and turn it off. So the lesson is when you first noticed something wrong you have to go back to basics and check everything. Remember when you ASSUME you make an ass out of U and me.
Just glad you were not hurt.
gdonham1 is offline
