Acrylic vs Polycarbonate and why? - Page 3 - Router Forums
 26Likes
post #21 of 26 (permalink) Old 10-14-2019, 06:11 PM
a little more on the subject...
File Type: pdf lexan_polycarbonate_sheet_processing_guide.pdf (2.54 MB, 9 views)
TenGees likes this.
post #22 of 26 (permalink) Old 10-23-2019, 09:12 PM
First Name: martin
Originally Posted by gmedwards View Post
One other thing. You can glue acrylic, by not polycarbonate. The glue is a very thin liquid and needs a special needle applicator to apply. I found the glue and applicator at a local plastics shop. Here's a link to what you need at Amazon:
https://www.amazon.com/Weld-Acrylic-Adhesive-Applicator-Bottle/dp/B0096TWKCW/ref=asc_df_B0096TWKCW/?tag=hyprod-20&linkCode=df0&hvadid=312719382368&hvpos=1o2&hvne tw=g&hvrand=8862313467348406152&hvpone=&hvptwo=&hv qmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargi d=aud-801381245258la-404766667839&psc=1&tag=&ref=&adgrpid=63696814698&h vpone=&hvptwo=&hvadid=312719382368&hvpos=1o2&hvnet w=g&hvrand=8862313467348406152&hvqmt=&hvdev=c&hvdv cmdl=&hvlocint=&hvlocphy=&hvtargid=aud-801381245258la-404766667839. It's been awhile since I've purchased any, but I believe was cheaper locally.
The ability to glue acrylic really expands its possibilities. As an example, several years back, I made a vacuum fence for my cabinet saw. It attaches to my Incra TS fence system. With a variable speed control on my vacuum, I can set the vacuum from light to so tight it's hard to feed the stock. It has completely eliminated kickback on my saw and ensure the stock remains tight against the fence. It's also very slick.
Gary
I used to use a product like this in 55 gallon drums. put into the needle applicator. on polycarbonate. it dried extremely quickly. https://www.amazon.com/Weld-Acrylic-...DMRDB2FAHRW9P2
radios is online now
post #23 of 26 (permalink) Old 10-23-2019, 09:41 PM
RainMan 2.0's Avatar
This isnít to relevant , but Iíll throw it in here anyways . Itís best not to cut or engrave lexan with a laser.
I knew this but accidentally did it. You canít even comprehend the horrible looking plasma ball of smoke that comes off Lexan, and it damages optics . This is why most companies will not put lexan on their laser engravers .
Itís so strange as plexiglass cuts beautifully with no visible smoke , almost leaves a sweet taste in the air , which I believe the byproduct to be co2 .
For some reason all of our glass shops stock plexi in 1/4Ē thick , but if you want 1/2Ē thick itís always lexan .
No idea why this is . Maybe Iíll ask next time
Ok ,I never insulate
RainMan 2.0 is offline
post #24 of 26 (permalink) Old 10-24-2019, 10:28 AM
Honored Member
harrysin's Avatar
First Name: Harry
https://www.cutplasticsheeting.co.uk...polycarbonate/
TenGees likes this.
Harry
harrysin is online now
post #25 of 26 (permalink) Old 11-04-2019, 06:23 AM
First Name: Dexcraft
Acrylic is shinier and cheaper than polycarbonate.
dexcraft is offline
post #26 of 26 (permalink) Old 11-04-2019, 09:32 AM
Honored Member
harrysin's Avatar
First Name: Harry
I've never noticed any difference, but admit that I've never actually looked for any difference in shine.
Harry
