Acrylic vs Polycarbonate and why? - Router Forums
 26Likes
post #1 of 26 (permalink) Old 10-07-2019, 04:19 PM Thread Starter
First Name: Ashley
Default Acrylic vs Polycarbonate and why?
I'm considering making my first custom sub-base for my Bosch 1617. It's less about necessity than trying something new, so I'm quite flexible.
I've read this fine thread and half a dozen others, used google to search this site, and viewed a dozen youtube videos. Everything about making sub-bases seems quite clear except this...
Key question: Do you use acrylic or polycarbonate, and why?
Bonus question: How thick? 1/2", 3/8", 1/4", other?
What's not being asked here...
  • I'm aware that acrylic is also known as plexiglass, plexiglas, lucite, and many other trade names. I'm aware that polycarbonate is also known as lexan, makrolon, and others. I'm not particularly interested (yet) in debating the various brands... only understanding clear acrylic vs polycarbonate, and desirable thickness.
  • I'm aware that a router sub-base can also be made from MDF (or almost anything else), though in this case I'm particularly interested in it being clear and easy to see through.
-Ashley
AshleyJ is offline
post #2 of 26 (permalink) Old 10-07-2019, 04:35 PM
One of my kids left a sheet of something in my shop. I’m not sure what it is but I made a table plate out of it. If you are making something like an offset base then just about any plastic sheet will be okay. A table plate might be more critical where sag is possible. I manage that possibility by not leaving it in the table when I’m not using it and having made it as small as I could. You don’t want it any thicker than it needs to be. Every 16th is a 16th less reach your bit will have but usually 5/16 to 3/8 is about right.
One consideration is that some plastics are prone to crack when you torque down flat head screws so you may want to counterbore holes and use pan heads screws instead.
TenGees and jj777746 like this.
post #3 of 26 (permalink) Old 10-07-2019, 04:37 PM
kp91's Avatar
First Name: Doug
Cast Acrylic. Cheaper than lexan, and you can find it lots of places. If just making a sub base you don't have to be that thick. If you are making an offset base or something you might want closer to 3/8".
If drilling thin acrylic look up ways to drill it without cracking it, such as grinding back the corners where the edge of the drill bit meets the flute so it doesn't catch and crack it.
TenGees likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 26 (permalink) Old 10-07-2019, 05:13 PM
difalkner's Avatar
First Name: David
Polycarbonate is stronger and more impact resistant. Acrylic is shinier and less expensive. Acrylic cracks easier and Polycarbonate is easier to scratch. Acrylic can be heated and bent to shapes while retaining its appearance, not so with Polycarbonate. Polycarbonate yellows over time, especially if in sunlight, but Acrylic remains clear.
There are obviously more pros/cons but this is the quick list I refer to when deciding which product to use.
David
TenGees and bhr like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #5 of 26 (permalink) Old 10-07-2019, 05:36 PM
I vote for polycarbonate... VOE...
keep in mind that acrylic is nick sensitive...
Acrylic plastic:
Less expensive than glass and polycarbonate
17x the impact resistance of glass
92% light transmittance in all thicknesses (better clarity than glass)
Insusceptible to yellowing or discoloration from the sun
Thermoplastic with a working temp of 180F continuous
Durable against scratches and dents
Sheets can be polished smooth
Easy to cut
Heat bent
Clean glue joints
Shiny surface
Large variety of colors available
Widths from 48” to 108”
Lengths from 72” to 192”
Recyclable
Polycarbonate:
250x the impact resistance of glass and 30x stronger than acrylic
Bullet resistant grades are available
88% light transmittance
Less rigid and available in a variety of flexible grades
Thermoplastic with a working temp of 240F continuous
Low level of flammability
Durable against chips and cracks
Highly resistant to acids and other chemicals such as gasoline
Sheets can be drilled without worry of cracking
Cold formed or bent without heating
Widthes from 38” to 75”
Lengths from 78” to 150”
Acrylic or Plexiglass Sheeting:
Pros:
Easier to machine than polycarbonate
Can be polished, both for scratches and clean edges
Better glue bonding
Shinier
Less expensive than polycarbonate by as much as 35%
Polycarbonate Sheeting:
Pros:
Greater strength than acrylic
More flexible than acrylic; can be shaped at room temperature
Can be exposed to high temperatures and is non-flammable
Highly resistant to chemicals
Can be drilled without cracking
Lighter in weight than comparable acrylic
Cons:
More rigid
More likely to crack during drilling or upon impact
More likely to chip
Should not be exposed to open flames
Cons:
Scratches easily
Can be dented easily
More translucent than transparent as compared to acrylic
post #6 of 26 (permalink) Old 10-07-2019, 05:46 PM
TWheels's Avatar
One factor to keep in mind is that polycarbonate ie a polymer of bis-phenol A (bPA), and the monomer leaches out when exposed to water. bPA acts as an estrogen mimic. Hence some care is needed during working, and the waste must be carefully disposed.
On the other hand there are very few side effects of using acrylic, a polymer of methyl methacrylate. It has been used in medical implants. It seems that there are few if any risks associated with the waste beyond that of any fine particulate.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 26 (permalink) Old 10-07-2019, 07:24 PM
David Bradford's Avatar
First Name: David
Thanks for all that info Stick.
David drafter @ Linear Fine Woodworking in Phoenix
[email protected]
http://www.linearfinewoodworking.com
David Bradford is offline
post #8 of 26 (permalink) Old 10-07-2019, 07:57 PM
all of the above...
post #9 of 26 (permalink) Old 10-08-2019, 10:25 AM
Honored Member
harrysin's Avatar
First Name: Harry
I prefer to use Poly-carbonate because it's tougher than Acrylics and routs without all the fluffy static laden swarf like Acrylics do. The first shot is Poly-carbonate 5mm and the second 4m Acrylic and I've had no problems with either.
TWheels likes this.
Harry
harrysin is offline
post #10 of 26 (permalink) Old 10-08-2019, 11:11 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
@stick
add the chart to the addendum library????
& perhaps to a sticky in the forum since a form of this comes up regularly
smitty
TWheels, MEBCWD and TenGees like this.
smitty10101 is offline
