Bearings for BOSCH 19054 Router - Router Forums
post #1 of 3 (permalink) Old 10-17-2019, 10:50 PM Thread Starter
Default Bearings for BOSCH 19054 Router
I am seeking replacement bearings for this BOSCH router 19054 but neither BOSCHTOOLS.com; ereplacementparts.com nor NACHI bearings have any reference to these parts. The factory installed bearings are
1)The large bearing near the cutter end is a NACHI “SR-12” width= 1 5/8” bore = 19mm; depth= 7/16”
2) The smaller bearing is NACHI BC 008L; width=24mm; bore=8mm; depth = 13/32”
Can anyone suggest where I can obtain replacement bearings for this router
Dennis Waller
[email protected]
ForeignAutoService is offline
post #2 of 3 (permalink) Old 10-18-2019, 09:27 AM
where are you located N/A...
you have MM bearings...
conversion doesn't work...
Stick486 is offline
post #3 of 3 (permalink) Old 10-18-2019, 07:15 PM
CharleyL's Avatar
First Name: Charley
Bearings are best purchased from bearing supply houses. You will get better bearings at lower prices. Look for bearing supply and power transmission stores in your area, or search for your bearing numbers through Google. Even Fastenal carries a good variety here in the US, but we can't help you more without knowing more about you and where you are located.
A first name would help too. Go to "Edit Profile" in the upper right corner and tell us a bit about you. Adding your name there will make is show in the box to the left of your post too. We already have too many N/a members.
Charley
Central North Carolina
CharleyL is offline
