Problem with my Triton router - Page 2 - Router Forums
 4Likes
post #11 of 15 (permalink) Old 11-04-2019, 02:59 AM
Carbatec
jw2170 likes this.
Holic46 is offline
post #12 of 15 (permalink) Old 11-04-2019, 06:32 AM
First Name: Dexcraft
I have the same router mounted in a table. Using only the big knob to raise it is difficult, because it's lifting on just one side, which causes binding. I generally turn the knob with one hand (squeezing the ring in with my fingers) and at the same time apply a little upward pressure with my other hand. If you are using the same technique (with height adjustment unlocked, of course) I don't know what the problem could be. Does the router plunge smoothly when not in the table?
Incidentally, I've installed a Wixey digital guage, and find I can get the desired height using the big knob only.
dexcraft is offline
post #13 of 15 (permalink) Old 11-11-2019, 01:32 AM
If you using router table mounted as shaper/moulder you must take out the plunger assist spring.
Holic46 is offline
post #14 of 15 (permalink) Old 11-14-2019, 06:23 AM
Hover's Avatar
Model of Triton...?
Hover is offline
post #15 of 15 (permalink) Old 12-05-2019, 02:21 AM
Default Thanks you
Thanks you
kokacak168 is offline
