I have a Triton router that I have been using and it has stopped working. It turns on just fine, the red light shows, but there is no activity coming from it... Any ideas what could be causing this? I have checked the switch and it seems to be fine, bypassing it doesn't help.
It is most likely variable speed controller. It happened to mine a couple of weeks ago. However, the new controller cost $140 and that was not an option for me to replace it as my router is about 20 years old. So I just took it out and connected directly. So now is revving at full speed - that does not really worry me.
Thank you so much for all of the help! Much appreciated. It was one of the connectors to the brushes, it had come loose. Tightened it with some thin nose pliers and problem solved.
I have the same router mounted in a table. Using only the big knob to raise it is difficult, because it's lifting on just one side, which causes binding. I generally turn the knob with one hand (squeezing the ring in with my fingers) and at the same time apply a little upward pressure with my other hand. If you are using the same technique (with height adjustment unlocked, of course) I don't know what the problem could be. Does the router plunge smoothly when not in the table?
Incidentally, I've installed a Wixey digital guage, and find I can get the desired height using the big knob only.
Related Threads
747K posts
128.1K members
Since 2004
