Problem with Dewalt Planer - Page 2 - Router Forums
 45Likes
post #11 of 35 (permalink) Old 11-02-2019, 09:13 PM
how would increasing the planer's exhaust port size, DC's line size and CFM flow rate???
post #12 of 35 (permalink) Old 11-02-2019, 09:18 PM
That's a pretty extensive and expensive remediation as opposed to taking the internal fan out.
Herb Stoops likes this.
DaninVan is offline
post #13 of 35 (permalink) Old 11-02-2019, 09:25 PM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
I just ran a board through a little ways with the hose off and it shoots chips into the next zip code. The DC only has one hose attached it I use it for the other equipment without a problem. Just ran it and put my hand over the end and it appears to be working fine.
difalkner likes this.
kywoodchopper is offline
post #14 of 35 (permalink) Old 11-02-2019, 09:31 PM Thread Starter
First Name: malcolm
I had never thought of that. I'll look into it. I wonder what the repair guy didn't think of that. Looks like it would be in their troubleshooting manual.
post #15 of 35 (permalink) Old 11-02-2019, 09:44 PM
Maybe the Helix cutter head does something to magnify the situation. More smaller chips that pack easily?
Just thinking out loud,
Herb Stoops is online now
post #16 of 35 (permalink) Old 11-02-2019, 09:59 PM
Last item: I found a number of DC collection setups that rely on the internal fan only. No DC involved. Just trash cans with an input port (4 inch) and screen to hold the fluff in. I'm not much on removing parts, but that's me. So, FYI only:
Name:	735 DC stand 3.jpg
Name:	735 DC stand 2.jpg
DaninVan and Herb Stoops like this.
post #17 of 35 (permalink) Old 11-02-2019, 10:11 PM
what size hose is on your DC???
post #18 of 35 (permalink) Old 11-02-2019, 10:13 PM
JFPNCM's Avatar
First Name: Jon
I’ve not experienced this issue with my 735 and it feeds an old Delta DC located some 30 feet away. Once I forgot to move the intake hose from the TS to the feed line for the 735 and ended up with chips blown not only through the length of the hose but about halfway back across the shop. Based on that humbling experience why not disconnect the Hose at the DC, run the 735 and see if the chips arrive there with force. If so, then there may well be a conflict between the 2 as noted earlier.
Jon
JFPNCM is offline
post #19 of 35 (permalink) Old 11-03-2019, 01:05 AM
Default Chip cure
I found the gasket from the the chip collector housing and the planer was worn and letting some chips out. On another site it was reported that a hole worn through on the back side of the blower housing. I put rags behind mine and it reduced the chips. I took it off to replace it and found the clip in the back holding the blower housing togrther un clipped. I reclipped it and reinstalled the blower. That cured the problem , no more chips inside the planner.
Cecil
rolfe is offline
post #20 of 35 (permalink) Old 11-03-2019, 07:37 AM Thread Starter
First Name: malcolm
I'll report back once I find a solution.
Did anyone see the 2nd part of my message about the dust port on the Bosch miter saw where I can't find a connector that fits?
Malcolm / Kentucky USA
Jimmy Dee and Herb Stoops like this.
