Router speed and hp large panel bits - Router Forums
 1Likes
  • 1 Post By mgmine
post #1 of 9 (permalink) Old 11-19-2019, 10:06 PM Thread Starter
Default Router speed and hp large panel bits
Hi, I am new in this forum seeking help. I have a triton 2 1/4 router. I recently purchased Amanda cope and style set including the panel bit. The documentation said the speed of the bit should be 12,000 rpm. That is no problem. But they also said the bit is to be used with a router at least 3 hp! I am thinking maybe light passes would work, but I am not sure if doing that would be a good idea. Does anyone have experience or tips about routing panel bits when you do not meet the specks of the bits? Any help would be highly appreciated.
Many many thanks
Ps would this do in my router and or me?
Badnewsz is offline
post #2 of 9 (permalink) Old 11-19-2019, 10:13 PM
welcome N/A...
hog out what you can on the TS...
on passes.. what is the recommended depth of cut and what do you think qualifies as a light pass???
to light of pass and the finer chips won't remove the heat generated by the cutting...
go to this link and there is in depth information on routering...
post #3 of 9 (permalink) Old 11-19-2019, 10:17 PM
maybe it's because so many got wind of the hypocrisies....
post #4 of 9 (permalink) Old 11-20-2019, 12:49 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I've mentioned many times here that horizontal panel raising bits scare the hell out of me so I use and recommend vertical bits and your router will have no problem.
Harry
harrysin is offline
post #5 of 9 (permalink) Old 11-20-2019, 07:41 AM
First Name: Art
For the speed listen to the sound the bit is making. If it sounds like an airplane it's too fast. You'll know it when you hear it. Even with a 3 hp it's a good idea to make several passes do the end grain first if using real wood. If MDF then it doesn't matter. I'm sure there are plenty of routers that claim to be 3 hp that aren't so I wouldn't be concerned about using yours. When using the rail bit make sure that you are also using feather boards to keep the wood tight to the fence and tight to the tabletop. When using the stile bit use something to keep it square to the bit. I use a miter gauge and a backup piece of wood to prevent splitting. If possible cut extra pieces in case something goes wrong during assembly.
harrysin likes this.
mgmine is online now
post #6 of 9 (permalink) Old 11-20-2019, 10:15 AM
roxanne562001's Avatar
First Name: Roxanne
Welcome to the forum
roxanne562001 is offline
post #7 of 9 (permalink) Old 11-20-2019, 01:36 PM
First Name: mary
marecat3 is offline
post #8 of 9 (permalink) Old 12-05-2019, 01:24 AM
Default Thanks you
Thanks you
kokacak168 is offline
post #9 of 9 (permalink) Old 12-19-2019, 05:34 AM
sanchez3's Avatar
Badnewsz, I've had such issues with my old router, and that's why I got a new one from DeWalt.
sanchez3 is offline
