Can you link 1 switch to another switch? - Router Forums
post #1 of 6 (permalink) Old 11-29-2019, 02:38 AM Thread Starter
Default Can you link 1 switch to another switch?
Hello!
I have a simple question I think. I want to connect for example 24 IP Cameras with ethernet cable and want to use 4 Switches that has
8 ports each.
I wonder if it is possible to connect the swithes in a SERIAL manner like this. So I would have something like 24 or more contacts to use?
Switch1 -> Switch2 -> Switch3 -> Switch4 -> Router
Thank you
thevlcuser is offline
post #2 of 6 (permalink) Old 11-29-2019, 02:50 AM
JOAT's Avatar
First Name: Theo
It does say ROUTER AND WOODWORKING DISCUSSION COMMUNITY right under Router Forums.com, at the top of the page. The router part means woodworking routers. So I'm confused. You talking about a woodworking router, or computer router?
JOAT is offline
post #3 of 6 (permalink) Old 11-29-2019, 06:09 AM
kp91's Avatar
First Name: Doug
Most switches will allow you to link to another switch, I don't know if you can go down multiple levels like that. In your example I would have a cable from switch 4 to each of the other switches, instead of daisy chaining them
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 6 (permalink) Old 11-29-2019, 01:36 PM
Country: South Africa
First Name: Biagio
You can only daisy chain three switches. More than that, you need to use stackable switches.
Biagio is offline
post #5 of 6 (permalink) Old 11-29-2019, 02:54 PM
RainMan 2.0's Avatar
I donít think heís taking no for an answer lol
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 6 (permalink) Old 11-29-2019, 03:14 PM Thread Starter
This sounds like an excellent solution as you mention to link the other switches from switch 4 instead of chaining them.
Thank you for that info.
I might also wonder, if the switches has GB speed. Then the router must also have GB speed if I understand to not make the router a bottleneck?.
Are there routers with specification like this?
