DW625 burnt out? - Router Forums
 19Likes
post #1 of 14 (permalink) Old 12-27-2019, 01:38 PM Thread Starter
Default DW625 burnt out?
It's my favorite router and I think I might have fried it. It's in a table with a fence. i adjusted the fence too close
to the cutter and when I started it, it of course did not turn (motor was trying). I couldn't get to the switch fast enough to shut it. Now it won't start. Is there a breaker in this router that I can reset, or is the motor fried? HELP
barrysboxes is offline
post #2 of 14 (permalink) Old 12-27-2019, 03:40 PM
welcome N/A..
take the brushes out and clean commentator......
rmark, jj777746 and artman60 like this.
post #3 of 14 (permalink) Old 12-27-2019, 06:43 PM
jj777746's Avatar
Lol
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #4 of 14 (permalink) Old 12-27-2019, 10:01 PM
No fuses inside. When a motor can`t turn or is working too hard it experiences a current rise through the windings. Usually you have a couple of seconds before this gets critical in a full stall but the high current load is too much heat for either the wire size or the shellac insulation on the wire to withstand for long.
DaninVan and RainMan 2.0 like this.
post #5 of 14 (permalink) Old 12-29-2019, 01:17 PM
TenGees's Avatar
First Name: Paul
Another possibility in that situation is the controller board (soft-start, speed control).
TenGees is online now
post #6 of 14 (permalink) Old 12-29-2019, 02:02 PM
With any luck it'll pop the breaker first. When ever I run into this no-go situation, I like to try it on a different plug on a different branch circuit, just to be sure it's not a house wiring failure.
I remember, several decades ago, when I worked for IBM, a common issue was two heavy draw pieces of equipment sharing the same phase in an office in a 3 ph. office tower. The simple solution was to plug one into a receptacle on a different phase. If the problems disappeared the issue was resolved.
Cherryville Chuck and Nickp like this.
DaninVan is offline
post #7 of 14 (permalink) Old 12-30-2019, 01:04 PM Thread Starter
Default The DW625 is NOT fried!
Had I done a little sleuthing I would have seen that the surge protector that it was plugged into did its job. It fried, not my router! Glad about that.
post #8 of 14 (permalink) Old 12-30-2019, 02:34 PM
Nickp's Avatar
First Name: Nick
Yippey, ki-oh, ki-ay...! ! !
Nick
Nickp is online now
post #9 of 14 (permalink) Old 12-30-2019, 03:29 PM
RainMan 2.0's Avatar
Thatís great news. Hopefully you stick around and share some of your projects with us
jj777746 likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #10 of 14 (permalink) Old 12-30-2019, 03:36 PM
Default Spare Parts...
Hopefully not an expensive replacement?
DaninVan is offline
