Utilitarian Cutting Board - Router Forums
 16Likes
  • 9 Post By bfblack
  • 1 Post By DesertRatTom
  • 1 Post By Cherryville Chuck
  • 2 Post By MEBCWD
  • 2 Post By bfblack
  • 1 Post By smitty10101
post #1 of 10 (permalink) Old 01-02-2020, 12:12 PM Thread Starter
First Name: ben
Default Utilitarian Cutting Board
A lot of people have shared really beautiful cutting boards that they have built. Many look more like pieces of fine furniture that should be displayed as a wall hanging or a coffee table item. I cringe at the thought of someone taking a knife to them! I want to share a cutting board design that is sufficiently plain that you won't mind attacking it with a knife. I got the design from a friend around 1968 so it has been around a long time. I presently have three of them in the kitchen and it is common to use two of them when preparing a nice meal. The sketch below gives typical dimensions that can be easily modified to suit your needs; the stock thickness can be in the range 1/2"-3/4". The three piece glue up evolved from the desire to make use of scraps and also minimize machine operations. The photo of a cutting board with curved joinery was the most elaborate one I have built; the two woods are cherry and maple. Curved joinery with a router is a topic for another thread. I have lost track of how many I have made and given to friends and family.
kp91, TwoSkies57, JFPNCM and 6 others like this.
bfblack is offline
post #2 of 10 (permalink) Old 01-02-2020, 01:46 PM
Bstrom's Avatar
First Name: Brian
What is the best glue to use on cutting boards - Titebond Extreme or Ultimate, or whatever the waterproof version is?
Bstrom is offline
post #3 of 10 (permalink) Old 01-02-2020, 02:31 PM
Type III ultimate. Long open time, waterproof would be my choice.
MEBCWD likes this.
post #4 of 10 (permalink) Old 01-02-2020, 02:51 PM
Or polyurethane. I’ve been laying a bead on and then spreading it with a plastic paddle from Lee Valley and using the paddle to scape off the excess and transfer it to the next piece. Very little squeeze out that way and the p u glue goes on thinner so I think cost is similar.
kp91 likes this.
post #5 of 10 (permalink) Old 01-02-2020, 03:18 PM
weldbond would be mine...
https://www.speedyproducts.com/produ...-new-packaging
post #6 of 10 (permalink) Old 01-03-2020, 10:29 AM
MEBCWD's Avatar
Nice looking convenient cutting board. Not so elaborate that it will never see the edge of a knife and good usable size.
TwoSkies57 and MT Stringer like this.
MEBCWD is offline
post #7 of 10 (permalink) Old 01-04-2020, 12:14 AM
Thanks for posting that design. It is quite utilitarian, I like the long grain cutting boards, and they are easier to make, I use Titebond II and never had a failure. The end grain boards are more for chopping,and the long grain ones are good for slicing. I have made several to span a single or double sink and have a hole in them for catching the scraps in a container in the sink.
When you make the dark/light boards do you make a dark one and a light one and lay one on top of the other to do the curved cut? Then swap pieces to get 2 dark / light colored ones, only opposites?
HErb
Herb Stoops is offline
post #8 of 10 (permalink) Old 01-06-2020, 07:05 AM Thread Starter
First Name: ben
Herb: The technique I learned does not make light and dark boards, band saw them and then switch parts. That approach might have the potential for minimizing waste. Instead, I made a template from 1/4" melamine or MDF that has the curved edge. This same template and a flush trim bit is used for cutting the curved (mating) edge of the light and dark woods. Hence you can get a (near) perfectly matched joint between the light and dark woods. At some point I will put together a document that goes into the details.
MEBCWD and Herb Stoops like this.
bfblack is offline
post #9 of 10 (permalink) Old 01-06-2020, 08:16 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Question
just curious----curiosity killed the cat---
Weldbond bottle says--"permanent and flexible"
"flexible" to what extent and under what conditions??
also seems to have left metal out of the things that it will attach to.
---correction-- the back of the bottle implies that it is not for metal & rubber
Herb Stoops likes this.
smitty10101 is offline
post #10 of 10 (permalink) Old 01-06-2020, 09:51 AM
as in not brittle..
metal... cast and AL is because of the nature of the metal...
check the PDF...
File Type: pdf Weldbond Specifications & Instructions.pdf (82.1 KB, 4 views)
