Home Brew Panel Saw Ideas? - Router Forums
 32Likes
post #1 of 23 (permalink) Old 01-13-2020, 03:46 PM Thread Starter
The Hobbyist's Avatar
First Name: Joe
Default Home Brew Panel Saw Ideas?
Okay ... so ... I procrastinate!
SEVEN years ago, I bought the components needed to build a large panel saw. I have the shiny polished slide tubes, the saw sled, the router sled, and some other components. I just have not taken the time to actually build the thing.
So it is on my “To Do” list for this Spring. Any suggestions? It is a long rail, 110” long. So when it is finally set up, it will be able to rip a 4x8 sheet vertically.
But I am like Tim Allen, and the character he plays on Home Improvement. I want to make it bigger, and better, and arg arg arg!
So I am considering a frame that will allow the saw to cut either vertically or horizontally, such that the whole thing would lay over like a table.
I have not selected a saw for it yet either. Suggestions? I want something powerful and able to handle thicker materials. I am even considering a carousel table so the material could be rotated around on the flat surface under the rail to slice up a sheet in any direction needed.
Since it is so large, there would need to be a drive chain or worm gear for it. I could not reach across such a large surface. Suggestions? LINKS?
What about hold downs for the material? Can you suggest pneumatic or electric hold downs I can incorporate into the design? Or would a vac table work better?
I would of course want to run a router on this thing also. I have a Bosch 2.25. HP. Router. That would work well I believe.
I would appreciate all input from you PROS!
Joe
Nickp likes this.
http://www.aguyintown.com
Retirement is overrated.
The Hobbyist is offline
post #2 of 23 (permalink) Old 01-13-2020, 03:48 PM
Tim is a hero to many of us...
jw2170, JFPNCM, Nickp and 1 others like this.
post #3 of 23 (permalink) Old 01-13-2020, 03:53 PM Thread Starter
First Name: Joe
I am part Tim Taylor, and part McGyver with a little Inspector Gadget thrown in for good measure.
Joe
jw2170, roxanne562001 and Nickp like this.
post #4 of 23 (permalink) Old 01-13-2020, 05:33 PM
PhilBa's Avatar
First Name: phil
You are getting closer and closer to the workings of a CNC router! Take a look at ACME screws for your drive. You can get up to 6' lengths pretty readily. You probably would want some gearing to increase the distance per turn if you are cranking it by hand.
I think for hold downs you could get away with a small number of toggle clamps for the corners. It's not going to take much to keep it in place.
Visit my shop website.
PhilBa is offline
post #5 of 23 (permalink) Old 01-13-2020, 05:48 PM
RainMan 2.0's Avatar
I was all gung ho to build a panel saw , then I joined here and learned about Track Saws .
Very happy I went with the track saw now , as it’s more versatile and can cut angles , plus it doesn’t take up a lot of room.
But each to his own
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 23 (permalink) Old 01-13-2020, 06:17 PM
PhilBa's Avatar
First Name: phil
Very happy I went with the track saw now , as itís more versatile and can cut angles , plus it doesnít take up a lot of room.
But each to his own
I am with you there. A lot of times, I will bring a 4x8 sheet or 3 home. Slide straight on to the saw horses from the truck and rough cut to project pieces with the track saw. No more muscling sheets around the shop. Keeps my Advil cost down.
PhilBa is offline
post #7 of 23 (permalink) Old 01-13-2020, 06:24 PM Thread Starter
First Name: Joe
But each to his own
Yes, angles! That is why I am picturing a turret platform for the saw. It would be maybe 100" and round, and perhaps 2" thick? It would have a zero or true vertical notch or pin hole or something to align it, as well as 45 and 90 degree pins. But it could also be rotated to any angle for a cut. Now this would require the material to lay against a spoil board of some sort so the blade could cut completely through the material, but there are plenty of cheap options for that. Perhaps I could use sheets of thick foam, set against something to hold them in place like a waffle rack. When one "tile" is consumed, it could be replaced cheaply with a new tile.
I do like the track saws. They are easy to set up and apparently give very accurate results. I have two nice table saws, but when I want to cut a 30" x 10' sheet of 3/4" Durasein (The knockoff brand of Corian ) it is too heavy for this old man to muscle around by myself. I purchased 15 sheets of Durian to experiment with, and I am LOVING the results! This is a test piece using a 1/16" two-flute bit with a 611 router.
Joe
HoweA and honesttjohn like this.
post #8 of 23 (permalink) Old 01-13-2020, 07:03 PM Thread Starter
First Name: Joe
I can't wait to try out my 1/32" bits!
Joe
post #9 of 23 (permalink) Old 01-14-2020, 07:40 AM
sreilly's Avatar
First Name: Steve
What the heck do you want with bear arms? I've seen bear rugs and mounted bear heads but just arms seems really odd to me Or did you mean "bare arms"?
Stick486 likes this.
sreilly is offline
post #10 of 23 (permalink) Old 01-14-2020, 12:01 PM
PhilBa's Avatar
First Name: phil
I prefer bare shoulders,
PhilBa is offline
