Enlarge a completed cut out circle? - Router Forums
 55Likes
post #1 of 24 (permalink) Old 02-22-2020, 04:49 AM Thread Starter
First Name: Jessie
Default Enlarge a completed cut out circle?
Now that I've finished my circle project, I ran into a gotcha...
Once I cut out the circle, it wasn't large enough by just a hair and I needed to enlarge the circle - about 1/4".
But, since the center was cut out, I couldn't figure out how to enlarge it with the router without doing it free hand.
I tried and almost really messed it up since I could not control the router around the circle, so I switched to my jig saw and did the best I could.
Is there (there must be) some technique or jig for enlarging a hole once it's been cut out?
Thanks as always in advance
newbie2wood is offline
post #2 of 24 (permalink) Old 02-22-2020, 06:56 AM
Country: South Africa
First Name: Hentie
Use a straight bit, with a guide bearing - then swap out the bearing with one where the radius of the bearing is 1/4 inch smaller.
so the first time you cut a rabbet.
then afterwards you just use a trim bit where the bearing and the bit are the same.
JFPNCM, Ray Y, MEBCWD and 6 others like this.
My daughter is willing to do small photoshop edits in exchange for LinkedIn likes. (bigger commissions to be discussed)
She just completed her concept art diploma through VANAS - Vancouver Animation School.
Watch her portfolio at https://www.nicorene.art
Please feel free to spread the word - it might just get her permanent employment.
lowracer is offline
post #3 of 24 (permalink) Old 02-22-2020, 07:07 AM
RainMan 2.0's Avatar
I would cut another circle out of a piece of material that would fit tightly inside the hole you have now ,thus providing a surface to secure to .
Or you can cut a bigger hole in another piece of material and secure it on top of your hole to act as a guide for a flush mount bit on your router and remove the excess material .
Is this a subwoofer box? I always do a test hole on another piece of material first. Once I get it perfect I save the plug for future woofers
newbie2wood likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 24 (permalink) Old 02-22-2020, 07:54 AM
First Name: Art
I would place another piece of wood under the hole and use that piece of wood to attach the trammel to. You might not be able to get the new circle in the exact location but as long as the bit was able to cut on all sides the circle would be round.
kp91, DaninVan, MEBCWD and 1 others like this.
mgmine is offline
post #5 of 24 (permalink) Old 02-22-2020, 08:01 AM
cut a bearing guided rabbet to desired depth...
switch to a bearing guided straight bit...
follow the inset wall of the rabbet w/ the straight finish to the size you need...
Stick486 is offline
post #6 of 24 (permalink) Old 02-22-2020, 09:22 AM
kp91's Avatar
First Name: Doug
Since you may have boogered up the shape of the original hole, I would agree with tacking your workpiece to a sacrificial board. Then take the center piece you cut out originally and tacking that to the sacrificial board, centered as best as you can. Use your circle cutting jig again.
You'll get a better looking circle, more practice with the jig, and less frustration.
harrysin, JFPNCM, MEBCWD and 2 others like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 24 (permalink) Old 02-22-2020, 09:52 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Wont that remove 1/2"? A 1/4" all round.
Harry
harrysin is offline
post #8 of 24 (permalink) Old 02-22-2020, 10:21 AM
chuckgray's Avatar
First Name: Chuck
True, but we don't know if the OP was referring to 1/4" radius or diameter.
chuckgray is offline
post #9 of 24 (permalink) Old 02-22-2020, 10:39 AM
If you still have the sacrificial backing board and it has both the center hole in it and the outline of the original circle showing (provided you cut into it slightly when you did the original) you can line the finished hole with that outline and then drill a piece of ply the same size and pin through it into the original center hole and simply cut a slightly larger circle. You'll be set up exactly the same the second time around.
DaninVan, MEBCWD, MYB and 1 others like this.
post #10 of 24 (permalink) Old 02-22-2020, 12:29 PM
The Hobbyist's Avatar
First Name: Joe
I just use the new Kreg Hole Stretcher.
Joe
kp91, JFPNCM, Rogerdodge and 1 others like this.
http://www.aguyintown.com
Retirement is overrated.
The Hobbyist is offline
