Hey I have PC/Rockwell 6302 which seems to be similar to porter cable 690. I also have an old craftsman router table. The mounting holes dont seem to line up with the router I have.
Anyway to make this work? If not is there current table out there I could use?
Stick if it's like an old Sears router table/router combination like one I had years ago the top is stamped metal and in the stamping they also countersink the metal for the mounting screws, something that is close to impossible to replicate by hand. I'm afraid in that case that the table is meant for one of Sears' routers and probably not even all of Sears' routers. If the top is thicker than about 1/16" thick then Stick's plan has a chance but you need more metal thickness so you can countersink for the screw heads.
The 690 was a very popular router at one time and there may be tables already drilled for it. Most modern tables have an insert plate that fits into a rabbet on the table top and it's easier to find plates that are drilled for that pattern. There is also a ton of info on this site about building your own and it really isn't that hard to do. Start simple and figure out what you want it to do and build a better one or ones later. I'm on about version 6 I think.
bore a smaller hole than required...
punch a dimple into the SM for the screws using a blunt pointed center punch like so...
be sure to solidly support the top w/ wood when you dimple the SM...
regrind the punch to match the screw head if need be...
howdy Adam...
use the router's base plate as a template and mark hole locations/placement w/ a transfer punch..
if you have one hole that lines up yur golden...
other wise double stick the plate into your desired position...
NOTE:
as a plus, you'll be leaving the plate off of the base when you install the router...
hole saw that fits the table's hole...
hole saw that fits the base plate....
put the two together on your arbor as line up guides... (one inside of the other)...
Related Threads
747K posts
128.1K members
Since 2004
