How to make these cuts? - Page 2 - Router Forums
 25Likes
post #11 of 20 (permalink) Old 05-18-2020, 12:45 AM
As has been suggested above, I would look at cutting the male and female parts on a router table - it doesn't have to be fancy, my first router table was a piece of 3/4" plywood with a cutout to clear the router base and a piece of 1/4" tempered masonite screwed to the top. Bolt through the masonite to the router and you're good to go. With the smaller router, it's better to rough out the center of the female slot with a straight bit, multiple passes so as not to overload the router, before cutting the finished shape with the dovetail bit. Cutting the slats is done with them vertical and guided by a tall fence - it would be easier if you could use a double featherboard set-up as shown to prevent any rocking of the slat as you cut - showing being used on a bandsaw, but the procedure is the same for a router table except you would be feeding right to left.. As explained in the article, sneak up on the depth of cut, removing material equally from both sides and checking for the correct fit in the dovetailed slot. Good Luck.
File Type: pdf Wider is better for resaw featherboards.PDF (36.6 KB, 20 views)
Stick486 likes this.
tomp913 is offline
post #12 of 20 (permalink) Old 05-18-2020, 09:44 AM
First Name: mary
Welcome to the forum
marecat3 is offline
post #13 of 20 (permalink) Old 05-18-2020, 10:43 AM
roxanne562001's Avatar
First Name: Roxanne
Welcome to the forum Owen
roxanne562001 is offline
post #14 of 20 (permalink) Old 05-20-2020, 07:03 PM
Oooh -- do you have a make/model number for those dual guides?
do you have a tablesaw and what router do you have w/ what accessories???
how about a router table???...
it'd be good to know what other tools you have...
did you already make those cuts???
the corner posts are cake and pie...
this Makita router shown is set up w/ opposing guides...
set your router up like this to cut the sliding DT slots...
how the slats are done depends on what other tools you have and your choice of materials......
''hogging'' out the waste materials before you cut the DT's will help w/ avoiding so much tearout...
using better bits is a major plus...
for router bits I'm partial to Freud and Whiteside bits...
ShoplessNewb is offline
post #15 of 20 (permalink) Old 05-20-2020, 07:33 PM
it's two separate guides set facing each other...
you can do it this w/ any brand as long as they have rods...
post #16 of 20 (permalink) Old 05-20-2020, 10:40 PM
In post #47 of this thread I show how to make your own. Should only take an hour or so at most and costs pennies. https://www.routerforums.com/tools-w...-corner-5.html
post #17 of 20 (permalink) Old 05-21-2020, 08:05 AM
RickKr's Avatar
...snip...
...snip...
That is an awesome setup. Thanks, Stick.
I have a Bosch 1617EVS and one of Bosch's guides like that. I can see I want another.
Rick
Name:	ROUTER + DUAL GUIDES.jpg
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
post #18 of 20 (permalink) Old 05-21-2020, 08:51 AM
Rick
yur welcome...
and you can increase the guide's face height for additional stability...
UHMW sheet is perfect for the task...
https://www.dollartree.com/cooking-c...8x11-in/300767
https://www.dollartree.com/home-coll...-boards/178253
https://www.biglots.com/search/?Ntt=Cutting%20Boards
post #19 of 20 (permalink) Old 05-21-2020, 09:01 AM
RickKr's Avatar
yur welcome...
Yup, I have some, what remains after making my crosscut sled runners and a few other things, 1/2"x4"x44".
Rick
RickKr is offline
post #20 of 20 (permalink) Old Yesterday, 02:47 PM Thread Starter
First Name: Owen
Thanks for all the guidance. Looking forward to exploring more into this with all the great info.
Owen Dawson is offline
