Picture frames - Router Forums
 52Likes
post #1 of 32 (permalink) Old 06-04-2020, 03:39 PM Thread Starter
Contributor of the Month
Bushwhacker's Avatar
First Name: David
Default Picture frames
Sandra came to me with a drawing she made of some wall panels to hold 4 x 6 inch printer size pictures. She wanted 3 of them.
After measuring and figuring the final size they would be. I hunted around my shop and found the material I would be using.
First I had several bundles of oak flooring. I have had them for about 20 years. I thought they would be a good choice to use for the frames of the panels.
First I cut off the tongue and then using a shaper bit, that I have had a set of for 20 some years, I ran the oak through my router table.
I clamped a 2x4 in front of the guide and one over the top of the bit to keep the material from riding up.
It took a couple of runs through to cut the oak all the way down.
Then removed one side of the groove side and 45ed the corners.
I had some 1/4 inch plywood that was large enough to fit as the backing for the pictures.
I cut 3/4 inch by 1/8th for the edge pieces to hold the pictures. I also cut a tiny groove in the bottom edge of each strip to hold the pictures.
The whole thing will be painted a flat black. That should make the pictures pop out.
I made 3 of these panels.
They are painted and drying at the moment.
Here are a few pictures of the build.
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #2 of 32 (permalink) Old 06-04-2020, 03:43 PM
well done David...
thanks for showing...
Stick486 is offline
post #3 of 32 (permalink) Old 06-04-2020, 03:49 PM Thread Starter
First Name: David
well done David...
Thanks Stick. Say, I just posted this and you have already seen and replied to it, how did you do that so fast?
I thought it would not be posted until tomorrows forum.
post #4 of 32 (permalink) Old 06-04-2020, 04:23 PM
luck of the draw...
there's a serious T&L storm in progress....
finished the househusband stuff early...
waiting on the lasagna to finish baking...
waiting for the bread dough to rise...
waiting for the crabs to flush clean...
waiting for the rug I just shampooed to dry...
waiting on the slow cooker to finish w/ the grouse...
the SO is napping and peacefully snoring away...
so I was just sitting here having coffee, listening to the storm and eating an experiment and your post popped up......
Coffee frosted Coffee Sticky Bun....
Ingredients:
1 cup chopped walnuts
4 tablespoon coffee extract or instant coffee or espresso granules (to taste)
1 (12 ounce) package frozen dinner roll dough
1 (5 ounce) package instant vanilla pudding mix
1 cup brown sugar
2 teaspoons ground cinnamon
½ cup margarine, melted
Directions:
Sprinkle nuts in the bottom of a greased Bundt pan. Lay frozen roll dough on top of the nuts. Sprinkle dry pudding mix over the dough, then the brown sugar, then the cinnamon. Pour the melted margarine over all. Lay a damp paper towel over the pan and place it in a cold oven over night.
In the morning, remove paper towel and place pan in cold oven. Heat oven to 350 degrees F (175 degrees C). Bake at 350 degrees F (175 degrees C) for 25 minutes. Remove from oven and let sit for 5 minutes, then flip out onto plate.
Coffee Frosting -
Ingredients:
1 tablespoon instant coffee or espresso granules
¼ cup milk
¼ cup unsweetened cocoa powder
6 tablespoons butter
1½ teaspoons vanilla extract
Directions:
Mix together; instant coffee or leftover coffee, milk, cocoa powder, butter or margarine, vanilla extract, and confectioners' sugar until of spreading consistency. Makes more than enough to frost a 13x9 inch sheet cake.
Cinnamon Coffee Frosting -
Ingredients:
1 teaspoon instant coffee granules
½ teaspoon ground cinnamon
1 pinch salt
1 teaspoon vanilla extract
½ cup butter, softened
3 cups confectioners' sugar
1/3 cup milk
Directions:
In a small bowl, mash instant coffee with the back of a spoon until powdery. Stir in cinnamon and salt. In a large bowl, beat the butter until smooth, then stir in spice mixture and vanilla. Alternately beat in confectioners' sugar and milk until desired consistency is achieved.
Chocolate Coffee Buttercream Icing -
Ingredients:
¾ cup butter, softened
1 (4 ounce) package cream cheese, softened
1½ (16 ounce) packages confectioners' sugar, or more as needed
3 tablespoons really strongly brewed coffee, or more to taste
½ teaspoon salt
Directions:
Beat butter and cream cheese together in a bowl with an electric hand mixer until creamy; slowly beat in confectioners' sugar, cocoa powder, coffee, and salt until smooth and spreadable.
Name:	COFFEE PASTRY.jpg
chessnut2, DaninVan, HoweA and 1 others like this.
Stick486 is offline
post #5 of 32 (permalink) Old 06-04-2020, 06:09 PM
Do you use your computer in an electric storm?? I lost 2 over the years doing that.
Just saying,
jj777746 likes this.
Herb Stoops is online now
post #6 of 32 (permalink) Old 06-04-2020, 06:22 PM
Just saying,
not normally..
Stick486 is offline
post #7 of 32 (permalink) Old 06-04-2020, 08:56 PM
MEBCWD's Avatar
David I like those frames. I should make some for my son and his wife to keep pictures of my grandson in. I should also make some for pictures of the two great granddaughters.
Nice project and could be scaled for any open space.
MEBCWD is online now
post #8 of 32 (permalink) Old 06-04-2020, 09:00 PM
RainMan 2.0's Avatar
Nice job David . I’ve never seen a router bit with a profile like that before . Certainly worked well for picture frames
Ok ,I never insulate
RainMan 2.0 is offline
post #9 of 32 (permalink) Old 06-04-2020, 09:44 PM
MEBCWD's Avatar
Here is a set, not sure of the quality but should be good for a few uses. Looks like that profile is in this set. https://www.amazon.com/Architectural...1324685&sr=8-2
Also check out crown molding bits for something like this.
Stick486, Herb Stoops and jj777746 like this.
post #10 of 32 (permalink) Old 06-04-2020, 10:55 PM
old55's Avatar
First Name: Ross
Very nice David.
Ross,
old55 is offline
